Vibrant peformance adjustable timing belt tensioner............ has any1 use this b4?
Old 12-19-2009, 03:19 PM
su8854's Avatar
Default Vibrant peformance adjustable timing belt tensioner............ has any1 use this b4?
http://www.turbomagazine.com/tech/07.../photo_06.html
im having a problem with my timing belt, after taking it apart about 10 times im getting belt slap on the exhaust to crank side of the belt. i think this would solve the problem and it seems good and all but what do you all think about this?
Old 12-19-2009, 05:24 PM
minilogoguy18's Avatar
Default Re: Vibrant peformance adjustable timing belt tensioner............ has any1 use this
http://www.importrp.com/product.php?productid=41997
I'd go with that one, it's all Honda OEM parts sold as a kit using the H23a1 manual tensioner. I bought this exact one and it came with everything needed, there is a write up in the FAQ on how to put it all together if you need.
Old 12-20-2009, 02:34 PM
su8854's Avatar
yeah i saw that but there was actually lots of work in putting this vibrant product together. im not sure bout long term effects.
Old 12-20-2009, 06:38 PM
But why use it when H22a and H23a1 block castings are identical so you can use reliable OEM parts that you know will work?
Old 12-20-2009, 06:50 PM
jlude90's Avatar
IMO its not a bad product, and its not meant to replace the honda tensioner from what i understand. And this product just take out a little extra slack that happens.
There is more info on this in the Drag forum I believe though.
Old 12-20-2009, 07:33 PM
Strange, most people complain about how tight the belt is when using the manual tensioner, not overly tight just hard to get the belt on and off.
Old 12-20-2009, 09:22 PM
jlude90's Avatar
Yeah, there is less slack, but the front side of the belt where there is a long distance from the crank gear to the cam gear, thats alot of room for flex
Old 12-21-2009, 05:01 AM
PirateMcFred's Avatar
Adding a tensioner there (like vibrant's product) affects the cam and ignition timing. If you're going to add a suplementary tensioner then you should put it between the intake cam and the waterpump where it won't affect timing. morons
Use the manual tensioner that can be found in the FAQ to increase tension/decrease slap. The auto tensioner will fail given enough time.
Old 12-22-2009, 05:17 AM
su8854's Avatar
i just got vibrants part fixed all problems and car runs like BRAND SPANKIN NEW + maby even better then that. i only had slack from exhaust -> crank. if i did the h23 mod it would only fix from crank -> intake cam which has enough tension. there was alot of slapping from exhaust - > crank and this fixed it
Old 12-24-2009, 02:41 PM
Mervin's Avatar
agreed with pirate, u should have adjustable gears to compensate for the changed timing
Old 12-25-2009, 05:42 AM
su8854's Avatar
yes but in pirate's stitution hes just wants more power. me? i just dont want my timing belt to slap it self off the pullys lol. no point of putting it inbetween water pump to intake if ant slapping there. its slapping HARD inbetweeen exhaust to crank which this stopped
Inextricabledrvr
05-23-2009 06:14 PM
fin781
02-13-2007 11:16 AM
BiscoSpek
07-23-2004 01:47 PM
domepizzle
06-11-2003 08:34 AM
MaxPowerIntegra
07-02-2001 05:08 PM
Quick Reply: Vibrant peformance adjustable timing belt tensioner............ has any1 use this b4?
