Skunk2 70mm TB Question!
#26
Re: Skunk2 70mm TB Question!
Damn! I guess, I'll have to sell it then. I can't return it now cause I bought it used from a guy off ebay.
But, I read Skunk2's installation and troubleshooting PDF and it said that if its sticking while butterfly is closed then to tighten the butterfly screw til it doesn't stick anymore. It also said that if it sticks while open, it needs a new return spring from Skunk2.
Oh well. I'll see how its like after I install it. Maybe it'll stick, maybe it won't if I'm lucky.
#27
I got a major question!
You guys see these spots that I circled?? Are they going to leak?
Also, the Thermal gasket is this thick. I know for a fact that the TB won't be able to touch the IM with a gasket that thick:
Let me know what you think, cause I got a feeling that I might have a vacuum leak. What gasket will I need?
EDITED: I think I must've installed the thermal gasket wrong in those pictures above. LOL Here's the correct way I believe:
But still, there's still that open spot thats not covered by the gasket and it will be expose. I believe that port is for the MAP sensor. Will I have vacuum leak then?
