Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Prelude (https://honda-tech.com/forums/honda-prelude-4/)
-   -   Problem with Crower valvetrain (https://honda-tech.com/forums/honda-prelude-4/problem-crower-valvetrain-2981604/)
pentaq Sep 21, 2011 12:44 AM
Hi,
I've a problem with Crower springs and retainers in the H22A7 (TypeS) head. Actually nothing is wrong with springs as the compress enough to lock them in place. The problem are retainers. I can't set a proper valve lash in 10-11 valves. After the inspection it appeared that the rocker arm was hitting/lean against the retainer before the adjusting screw even approached the valve.
Did anyone experience such a problem? What to do with that?
bluedlude Sep 21, 2011 03:08 AM
Re: Problem with Crower valvetrain
That has been a well documented problem with the crower valvetrain from day 1. It's not your fault man. Most people just make a relief in the rocker arms to clear the retainer.
pentaq Sep 21, 2011 06:28 AM
Where can I find more info on this? Thanks a lot.
Edit: nvm I found it. Anyway thanks again for enlightment. :) I don't like the grinding rocker arms idea. We're going back to OE retainers and stiffer springs.
NirVTEC Sep 21, 2011 04:34 PM
Good ole Crower! YeeHAaa!!!
