Prelude/H-series Transmission Codes and Ratios master-list
Old 06-07-2011, 04:10 PM
  #51
minilogoguy18's Avatar
Default Re: Prelude/H-series Transmission Codes and Ratios master-list
Pirate has a thread that will show you how to find the gear ratios so that you can compare, never heard of a P2T4.
No to slammedbbs, the higher the number the shorter the gear.
Old 06-07-2011, 05:06 PM
  #52
slammedbbs's Avatar
oh ok well i just found out a had a 92-96 tranny in my bb6....and the chart shows they have shorter gears i like short gears thanks minilogoguy
Old 06-30-2011, 03:25 PM
  #53
hondaspeder's Avatar
Does anyone know if all of the F/H transmissions on this list have the same cable attachment points? or are all of these transmissions interchangeable with each other?
Old 06-30-2011, 03:26 PM
  #54
They do and they all are interchangeable.
Old 04-04-2012, 07:01 PM
  #55
hondanerd87's Avatar
awesome love the help from this thread
Old 12-27-2012, 06:37 AM
  #56
KRITIK's Avatar
jus a quick question pls no flaming.
For the list where LSD is placed are those the only transmission that come with LSD from factory. is this confirmed.
i asked bcaz i will be going hunting for a transmission soon, and i called a parts shop they say they have a H23 wit and LSD on it, but from the list i see no H23 that comes with and LSD transmission.
Will post the code as soon as i get a chance to look at it
Old 12-29-2012, 10:25 AM
  #57
BergRacing21's Avatar
all the trannys on the list that note that they have LSD do from factory. As far as i know, no H23 trannys came LSD equipped but that doesn't mean that the shop hasn't installed one into an H23 tranny so the code might not be helpful cause we wont know if someone installed one or not.
Old 02-02-2013, 07:08 PM
  #58
kristeenuh7's Avatar
Ok, so heres a question, the gear ratios are the same but will a P2U5 manual tranny (94-97 f22B1) work for my 90 honda accord (F22a1, h2a5)?
Old 10-09-2013, 08:40 AM
  #59
CTCD5's Avatar
Noob question but which are 5spd and which are auto?
Old 01-11-2015, 04:33 PM
  #60
HT_lude's Avatar
do you know where i can get this write up, need to identify a transmission
Old 07-06-2015, 04:48 AM
  #61
fastludeh22's Avatar
What happened to the chart? It worked 2 days ago. Anyone still have the pics/chart?
Old 07-06-2015, 08:38 PM
  #62
Moderator
crazes's Avatar
double check again because it worked right now when I checked it.
Old 04-28-2016, 08:59 AM
  #63
Rob777's Avatar
Help. I have a 1994 Honda accord that I need to shorted the gear ratio. would a M2S4 tranny out of a prelude bolt right up to my motor it has a F22b2 2.2 non vtex.
Old 07-05-2016, 09:51 PM
  #64
Go Tigers!
Bense's Avatar
In this chart, the 1992-1996 USDM Prelude S - BA8 - F22A1 - M2L5 - has incorrect values. It lists the 1-5 gears as:
{3.310, 1.810, 1.232, 0.900, 0.710}
Take note of the 1992-1996 Accord Wagon model 1-5:
{3.307, 1.809, 1.230, 0.903, 0.705}
If you were to round all of the wagon ratios to 2 decimal places, you wind up with the values given for the prelude S, with exception of the 3rd gear of 1.232. Must have been a typo because the first numerical possibility of 1.232 is 53/43, which is tooth count combination that is far to much of an outlier for it to be likely.
The correct values are the ones listed for the Wagon.
I'm going to go ahead and post another table I found on some other forum. I am not going to cite where, because they also said that they'd just copy/pasted from some other forum. For reference.
Tranny Code + It's Origin
M2A4 - JDM 4G
M2B4 - JDM 4G LSD
M2F4 - USDM 4G
M2U4 - JDM 5G Type-S ATTS/USDM Type-SH ATTS
M2Y4 - JDM/USDM 5G Base
M2Z4 - JDM 5G SiR S-Spec/JDM 5G w/ LSD option
T2T4 - JDM Accord SiR-T (F20B) LSD
T2W4 - JDM Accord Euro-R LSD
U2Q7 - EDM Accord Type-R LSD
M2T4 - BB6 H22A SiR LSD
M2L5 92-96 Prelude S (F22A1)
M2S4 92-96 Prelude Si (H23A1)
M2J5 92-96 Prelude Si (JDM F22B)
P2A5 94-97 Accord DX/LX
P2U5 94-97 Accord EX
P2A4 94-97 Accord Lx/EX Wagon
M2J4 - EuDM 2.0i (F20A4)
M2K4 - EuDM 2.3i 4ws (H23A2)
M2F5 - EuDM 2.2i VTEC (H22A2)
M2X5 - EuDM 5g Vti-S (H22A5)
M2V5 - EuDM 5g Vti 4WS (H22A5)
M2P4 - EuDM 5g Vti-S 4WS
M2R4 - Vti-S 1999<-updated?
M2C4 - 4th gen BA8 (F22A2)
Tranny Code + Gear Ratios
M2A4 - 3.307 - 1.950 - 1.360 - 1.034 - 0.787 - 4.266
M2B4 - 3.307 - 1.950 - 1.360 - 1.034 - 0.787 - 4.266 LSD
M2F4 - 3.307 - 1.950 - 1.360 - 1.071 - 0.870 - 4.266
M2U4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 ATTS
M2Y4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266
M2Z4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 LSD
T2T4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 LSD
T2W4 - 3.285 - 2.090 - 1.481 - 1.071 - 0.812 - 4.266 LSD
U2Q7 - 3.285 - 2.090 - 1.481 - 1.071 - 0.870 - 4.266 LSD
M2T4 -
M2L5 - 3.307 - 1.810 - 1.230 - 0.903 - 0.705 - 4.062
M2S4 - 3.307 - 1.857 - 1.320 - 1.034 - 0.812 - 4.266
M2J5 - 3.307 - 1.810 - 1.269 - 0.966 - 0.787 - 4.062
P2A5 - 3.307 - 1.809 - 1.185 - 0.903 - 0.685 - 4.062
P2U5 - 3.307 - 1.809 - 1.185 - 0.933 - 0.685 - 4.062
P2A4 - 3.307 - 1.809 - 1.185 - 0.903 - 0.685 - 4.062
M2J4 - 3.285 - 1.807 - 1.266 - 0.966 - 0.787 - 4.266
M2K4 - 3.307 - 1.809 - 1.269 - 0.966 - 0.757 - 4.266
M2F5 - 3.307 - 1.950 - 1.360 - 1.071 - 0.870 - 4.062
M2X5 -
M2V5 - 3.285 - 1.950 - 1.344 - 1.071 - 0.870 - 4.062
M2P4 - 3.285 - 2.090 - 1.481 - 1.071 - 0.870 - 4.266
M2R4 -
M2C4 - 3.307 - 1.809 - 1.230 - 0.933 - 0.757 - 4.266
__________________
Old 07-05-2016, 09:52 PM
  #65
Go Tigers!
Bense's Avatar
Some more pastes:
USDM F22A1 90-93 ACCORD DX/LX COUPE/SEDAN:
Diff Type & Tranny Codes:
STD Only = MPT3
3.307 1
1.809 2
1.230 3
0.903 4
0.705 5
4.062 final
5th gear 195/60 R15
70mph = 2782 rpm
80mph = 3180 rpm
USDM F22A4/A6 90-93 ACCORD EX COUPE/SEDAN:
STD Only = H2U5
3.307 1
1.809 2
1.185 3
0.870 4
0.685 5
4.062 final
5th gear 195/60 R15
70mph = 2703 rpm
80mph = 3090 rpm
USDM F22A1 92-96 Prelude S COUPE:
STD Only = M2L5
3.307 1
1.809 2
1.230 3
0.903 4
0.705 5
4.062 final
5th gear 195/60 R15
70mph = 2782 rpm
80mph = 3180 rpm
USDM H23A1 92-96 PRELUDE Si COUPE:
STD Only = M2S4
3.307 1
1.857 2
1.320 3
1.034 4
0.812 5
4.266 final
5th gear 195/60 R15
70mph = 3366 rpm
80mph = 3847 rpm
USDM H22A1 93-96 PRELUDE VTEC COUPE:
STD Only = M2F4
3.307 1
1.950 2
1.360 3
1.071 4
0.871 5
4.266 final
5th gear 195/60 R15
70mph = 3610 rpm
80mph = 4126 rpm
USDM H22A4 97-01 PRELUDE VTEC Non-SH COUPE:
STD Only = M2Y4
3.285 1
1.956 2
1.344 3
1.034 4
0.812 5
4.266 final
5th gear 195/60 R15
70mph = ? rpm
80mph = ? rpm
JDM H22A 92-96 PRELUDE VTEC COUPE:
STD = M2A4
LSD = M2B4
3.307 1
1.950 2
1.360 3
1.034 4
0.787 5
4.266 final
5th gear 195/60 R15
70mph = 3262 rpm
80mph = 3728 rpm
USDM F22B1 94-97 ACCORD EX VTEC COUPE/SEDAN:
STD Only = P2U5
3.285 1
1.807 2
1.193 3
0.933 4
0.685 5
4.062 final
5th gear 195/60 R15
70mph = 2703 rpm
80mph = 3090 rpm
USDM F22B2 94-97 ACCORD DX/LX non-VTEC COUPE/SEDAN:
STD Only = P2A5
3.285 1
1.807 2
1.193 3
0.903 4
0.685 5
4.062 final
5th gear 195/60 R15
70mph = 2703 rpm
80mph = 3090 rpm
USDM F22BX 94-97 ACCORD LX/EX WAGON:
STD Only = P2A4
3.285 1
1.807 2
1.193 3
0.903 4
0.685 5
4.266 final
5th gear 195/60 R15
70mph = 2839 rpm
80mph = 3245 rpm
JDM F20B ACCORD SiR-T VTEC:
LSD = T2T4
3.285 1
1.956 2
1.344 3
1.034 4
0.787 5
4.266 final
5th gear 195/60 R15
70mph = 3262 rpm
80mph = 3728 rpm
JDM F22B Prelude Si non-VTEC:
STD = M2J5
3.307 1
1.810 2
1.269 3
0.966 4
0.787 5
4.062 final
5th gear 195/60 R15
70mph = 3106 rpm
80mph = 3550 rpm
JDM ACCORD Euro-R VTEC:
LSD = T2W4
3.285 1
2.090 2
1.481 3
1.071 4
0.812 5
4.266 final
5th gear 195/60 R15
70mph = ? rpm
80mph = ? rpm
EDM ACCORD Type-R VTEC:
LSD = U2Q7
3.285 1
2.090 2
1.481 3
1.071 4
0.870 5
4.266 final
5th gear 195/60 R15
70mph = ? rpm
80mph = ? rpm
JDM PRELUDE SiR S-spec:
LSD = M2Z4
3.285 1
1.956 2
1.344 3
1.034 4
0.812 5
4.266 final
5th gear 195/60 R15
70mph = ? rpm
80mph = ? rpm
Old 07-05-2016, 09:55 PM
  #66
Go Tigers!
Bense's Avatar
Some more pastes:
Transmission Parts - 6th Gen Accord DIY and Performance Forums
Old 07-08-2017, 03:56 PM
  #67
Go Tigers!
Bense's Avatar
Here's the ratios.
Old 05-19-2018, 06:39 PM
  #68
MaurizioRuiz's Avatar
Originally Posted by Kronn 98SH
Another chart brought to you by Kronn.
Attachment 471568
Attachment 471569
Attachment 471570
Attachment 471571
Keywords: H2A5, H2C4, H2S8, H2U4, H2U5, M2A4, M2A5, M2B4, M2C4, M2F4, M2F5, M2J4, M2J5, M2K4, M2L5, M2P4, M2R4, M2S4, M2T4, M2U4, M2V5, M2X4, M2X5, M2Y4, M2Z4, N2C4, N2D4, N2E5, N2S4, P2A4, P2A5, P2A8, P2C4, P2U5, S2A4, S2A8, T2C5, T2T4, T2W4, U2G5, U2J4, U2L4, U2N4, U2Q7
Hello, I'm new here. I'm looking at these charts you have here. Does it mean that all of those accord years and models are compatible with a 1998 Honda Prelude. I have an automatic h22A4 in mine.
hondafdj444
10-26-2013 11:56 PM
demonhunterlevin
07-16-2006 09:41 AM
ILoveMyBB6
12-15-2005 09:43 AM
4g4me
05-20-2002 07:52 PM
Quick Reply: Prelude/H-series Transmission Codes and Ratios master-list
