Idle problem with H23A Vtec
Old 04-16-2012, 02:25 PM
catchdz's Avatar
Default Idle problem with H23A Vtec
i have a question, i put the h23a into my 96 prelude si, when i went to plug everything in the iacv was different so i put the top of the intake & TB on from my h23a1. now i have a problem with it idling at like 1500 to 2000 rpms, i changed the iacv for a new one, nothing happened still messed up, so i put and old one on and nothing im not sure what to do. when i was messing around with the car one day i realized that my cold air intake was really loud so i took it off, thinking the filter was dirty. As i was F&(ing with things i cover one of the holes with my finger and the idle dropped back down to normal so i tried covering both holes the car wants to cut out, does ne one have ne ideas about what the hell is going on??????
Also i coverted everything back to obd1 and i am using a chipped p06
Old 04-16-2012, 08:24 PM
minilogoguy18's Avatar
Default Re: Idle problem with H23A Vtec
Ignition timing and doing the idle learn procedure would be 2 good places to start. Download the manual from spoonertuner.com if you're not familiar with how to do the idle learn procedure.
Old 04-17-2012, 11:25 AM
catchdz's Avatar
thanks ill see whats up with that? if u think of ne thing else hit me up
Old 04-19-2012, 07:24 AM
Rosko's Avatar
What do you mean by "chipped P06"? Was it dynotuned for this setup? Ignition timing and fuel are probably incorrect for you application causing your erratic idle.
Old 04-19-2012, 12:21 PM
catchdz's Avatar
yeah it was chipped and tuned for my car but i dont think ne of that is the problem i changed the piece that sits under the throttle body the bypass or what not i changed that and most of my problems went away for the most part, i thank u both for ur help. Do u guys know me thing about a code 9 i cant get rid of?
DC2andED6
05-09-2009 02:55 PM
alexdbest2000
12-14-2008 01:05 PM
supradrifter
12-19-2006 08:43 AM
lilCivic
02-02-2005 05:36 PM
walsredprelude
10-30-2004 09:42 AM
Quick Reply: Idle problem with H23A Vtec
