::The Official Prelude 1/4 mile thread::
Old 07-02-2014, 10:14 AM
  #876
Default Re: ::The Official Prelude 1/4 mile thread::
here is the video of qualifying at IREV where I ran the 10.69. its the 3rd pass in the video @ 1:02. I also ran 10.67 at summer slam over the weekend with a horrible 1.90 60'.
Slow@ssLuda is offline
Old 06-16-2015, 04:49 PM
  #877
BergRacing21's Avatar
I'm in the third run of this video, this pass was a 12.7 blew a charge pipe off 9.1 seconds into the run. Trapped at 95
Here's the time slip of my best and so far fastest time. same setup, still stock block just pushing 19 psi now. Still on Pump 93 and using small tire M&H
BergRacing21 is offline
Old 06-18-2015, 07:40 AM
  #878
Moderator
snobordboy's Avatar
Updated list, down to 5 of 20 on spray. Yikes.
I know there are one or two 9-10 second ludes that aren't on here as well, but don't haev enough info to add them.
snobordboy is offline
Old 12-07-2015, 04:10 PM
  #879
New PB [email protected] lol guess im tied for the top 10 now...bummed i didn't get 11's this year but i got some things to work out and change over the winter and i'll be back out faster!
Old 01-23-2016, 09:09 AM
  #880
motoxxxman's Avatar
I don't have my time slip, but this is a vid from October 2009. my engine setup is a little different now, but this is the setup from this video:
1990 prelude Si
b20 block bored to fit oem b21 pistons, oem h23 rods, b21 exhaust cam, b20 intake cam, b21 head and intake manifold, supertech valve springs, tubular EQ turbo mani, super 60 t3, 9psi, 22x8x15 MT Drags
12.81 @109.5mph
motoxxxman is offline
Old 01-25-2016, 09:46 AM
  #881
Moderator
snobordboy's Avatar
So close, you will be there before long!
You have the #10 for now, verified time and higher trap speed.
Old 02-01-2017, 06:09 PM
  #882
2001 Prelude Base
Stock longblock
Ported Intake Mani
70mm TB
Tri-y header
2.5in exhuast
MT ET STREET R 225/50R15
FULL INTERIOR, AC, POWER STEERING
HONDATA S300V3
NX WET KIT
[email protected] at Great Lakes Dragaway in Wisconsin
Josh Brown
XplicitBB6 is offline
Old 02-02-2017, 04:30 PM
  #883
motoxxxman's Avatar
New time for my current setup! :D
9.8:1 83.5mm b20a block, custom JE pistons, OEM h23a1 rods, ACL Race bearings, ARP head studs, Cometic HG
B21 head with port smoothing and port matched, stock b21 intake mani, stock valves, supertech springs, b21 exhaust cam, b18a intake cam.
EQ SS tubular mani, super 60 t3 0.63a/r, 14psi, e85
60' - 1.866
1/8th - 7.774
MPH - 92.47
1000ft - 10.062
1/4 - 11.995
MPH - 116.46
BARO 29.29, 56.3F, HUM: 41%, CALT: 702
tires used - Hoosier 24.5x9.5x13 on 13x8
which bumps me from #17 to #8, for the time being. And is the new world record for the 3g chassis without a motor swap :D
Stay tuned for even faster times come spring
https://www.youtube.com/watch?v=6sUduq1BLiA
Old 02-03-2017, 06:02 AM
  #884
Moderator
snobordboy's Avatar
Nice, I will have the list updated later today.
Old 02-04-2017, 09:47 AM
  #885
850Fabrication's Avatar
can fix my technical time while your at it
11.85 @116
850Fabrication is offline
Old 02-06-2017, 06:12 AM
  #886
Moderator
snobordboy's Avatar
Haha sure Blake, done.
I am just about knocked off the list, might have to stop building Subaru engines and get the 2.3 back together and into the Lude again haha. I think I still have a full bottle of nitrous chilling in the basement, unless I can find some way to sneak the turbo setup I want in, maybe sell the WRX and keep the wife happy haha.
Old 10-15-2017, 08:51 PM
  #887
motoxxxman's Avatar
Bumped my times down a bit, still same position in the list though. But still the world record holder for the bastard B!
First run out my clutch decided to slip in every single gear. It's 2 years old, and rated for about 10ft/lbs less than I made on the dyno, so I chould have expected it. Oh well, new clutch coming soon.
So for the rest of the day I: was not preloading (to prevent clutch heat), launching a bit gently, slow shifting, and not going full throttle until I knew the clutch was fully seated after every shift. I still managed to run:
1.833 - 60'
5.113 - 330'
7.670 - 660'
95.79 - 1/8 mph
9.853 - 1000'
11.696 - 1320'
121.86 - 1/4 mph
turbo 3g. same setup as my above comment, but some more boost, a hair more weight shaved off, and a traction bar and motor mounts. Had the clutch not been slipping, I feel like I easily should have gotten below 11.4. Spring isn't too far away...
Old 10-16-2017, 05:57 AM
  #888
Moderator
snobordboy's Avatar
Nice Steve. Get a better clutch in there and let's see her rip.
How high are you revving it?
Old 10-16-2017, 01:37 PM
  #889
motoxxxman's Avatar
thanks I definitely plan on it. I have a whole custom top end in the works too that I plan to have ready for spring, see if I can hit 500hp with the same t3
First gear I rev to 7500-7600, everywhere else only to about 6800-7000 due to top end taking a dive, for now...
Old 10-23-2018, 07:54 AM
  #890
Honda owns me
typemismatch's Avatar
No updates for a year huh?
Preludes dead or what?
I might have to drag mine back out in 2019 and move up the list for funsies.
typemismatch is offline
Old 10-24-2018, 03:28 AM
  #891
LOL. I was beginning to think the same thing! I unfortunately basically took this whole year off, due to having my first child (she's amazing, don't regret it. Family first, fun second). I did do some 1/8th miles events earlier in the year, which by the numbers the car should be going easily mid to low 11's now. So who knows i might try to hit MIR last event in November, otherwise I'll definitely be out in 2019 ready to make a splash.
Old 10-24-2018, 09:24 AM
  #892
Moderator
snobordboy's Avatar
Yeah not many guys running Ludes right now.
Personally I killed an engine on the dyno, so it's still taken apart, had a kid, got separated, moved back to Colorado. The engine and parts are back in Toronto, but the car is running a stock internal H22 for now, so no new #s coming even if I were to go run it. My SUV is about as fast and much nicer to drive haha.
Old 10-24-2018, 07:16 PM
  #893
motoxxxman's Avatar
I'll be posting faster times in spring. I just haven't upgraded my clutch yet, even though I raised the power up more haha, and am now dealing with breaking third and fourth gear.
Old 10-31-2018, 12:28 PM
  #894
Honda owns me
I've had a twin disc for mine collecting dust for about 5 years. I have a few other small updates and I should get it out in 2019 to make a hit.
Personally ended up getting an R and building an all motor H2b as well as a million other things that have kept me busy, broke or some other lame *** excuse ...
Old 10-31-2018, 02:32 PM
  #895
Moderator
snobordboy's Avatar
That's funny, I have a twin disc and scatter shield for the "future plans" on my car as well, just sitting in the garage at the ex's place. Luckily she doesn't care, and won't do anything with them.
No lie, a 640 HP SUV manages to eat plenty of money, so all of my other cars have been neglected.
EF Sedan Enthusiast
Group Threads
67293
04-08-2019 09:05 AM
cd5_2NR
Group Threads
8666
11-29-2018 02:29 PM
freakin_eLRoD
Group Threads
34047
01-19-2018 07:04 PM
NorCal EM1
Group Threads
380
10-21-2017 04:06 AM
zuptidi
04-04-2017 09:06 PM
Quick Reply: ::The Official Prelude 1/4 mile thread::
  • Ask a Question
Question Title:
Description:
