I just installed a skunk 2 70mm throttle body
I would like to know what can I do because i'm not adding boost it's an N/A motor After I got that it's a throttle body put on. I punch it to the floor and my check Eng in my instantly pops up. Of course. It doesn't have the greatest Idel That being said I had two coats here they are P0123 and (p1128 pd) Any suggestions I actually saw a skunk too 70 mm throttle body with a new map sensor but that's not the one I got mind came just to throtttal body and just the hardware. I wanna keep the throttle body. Can I just buy a new map sensor but also i'm looking at prices. Sorry it posted double pictures. The ones that I originally took didn't pop up so I just re added them
Just showing you the codes This one Is popped up right after I Erase the codes within a matter of minutes
This one also. Popped up within a matter of minutes after being erased twice
If anybody has any ideas please let me know
This one comes with different sensors so maybe that might fix it?
I drove the car and open throttle to check engine light turned on and. I erased both this code and another and they popped right back up within a matter of thirty seconds or if I hit full throttle any advice would help
Premium Member
Re: I just installed a skunk 2 70mm throttle body
TPS code is likely because it's not installed/calibrated correctly.
Also you really don't need a throttle body that big on a stock engine. Likely lost power and throttle response.
