Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Reload this Page >
New Frankenstein Engine = G23 (F23/H23 write up, Long, 56K beware)
Old 03-20-2012, 05:07 PM
  #776
InvaderTrax's Avatar
Default Re: New Frankenstein Engine = G23 (F23/H23 write up, Long, 56K beware)
The G23 VTEC thread would be better for this, but I'll ask here anyway. If you were to take an H22 head and F23 block, could you put it together with an H23 belt with H23 upper and lower timing gears? I'd rather not have to source the H22 parts if I don't have to, plus my timing belt has 10k miles on it
InvaderTrax is offline
Old 03-21-2012, 05:01 AM
  #777
jdchmiel's Avatar
sohc and dohc motors have different belt lengths, so no, you cannot.
jdchmiel is offline
Old 03-21-2012, 04:06 PM
  #778
You read my post wrong.
Anyway, I got the info I needed. H23 cam gears won't fit H22 cams, so that's pretty much the end of that idea. I'm not so sure about reving a basically stock F23 bottom end to 7500 anyway
Old 08-29-2012, 02:06 PM
  #779
Does anyone have the original write up?
hooligan13 is offline
Old 09-26-2012, 12:27 AM
  #780
lCHaCHeel's Avatar
i would also like to know ^^
lCHaCHeel is offline
Old 09-26-2012, 06:31 AM
  #781
Rosko's Avatar
I am almost 100% positive that they WILL. I started out back in the day with an H23 motor, had AEM cam gears and then later went with an H22 setup. I took the gears off the H23, machined a new outer ring gear (where the belt rids) and then had to make a washer to go behind the gear to space it out correctly. The inner hub was reused and fit the diameter of the cam, I just needed to make spacers and of course make a new outter gear but you wouldnt need to do that if you were using the H23 belt.
I know your post is old and its probably not worth modifying, just throwing that out there.
Rosko is offline
Old 10-21-2012, 12:33 PM
  #782
unuselectus's Avatar
What happened to the write-up???
unuselectus is offline
Old 10-21-2012, 02:54 PM
  #783
Moderator
crazes's Avatar
the user was not happy with some things that was done by other members and erased it
crazes is offline
Old 10-24-2012, 02:03 PM
  #784
lude72's Avatar
its sad it had A LOT of good info.....
lude72 is offline
Old 11-04-2012, 02:14 PM
  #785
i have many k20 rods and 3 prc k20a type piston for real cheap if anyone need for their g23 built...
p1mmiz321 is offline
Old 11-29-2012, 07:03 PM
  #786
Do I change the timing crank gear when I put a h22 head on a f23 bottom end? Let me know as soon as possible please..
BKG Performance is offline
Old 12-05-2012, 05:15 PM
  #787
asianpoet's Avatar
anything that the h22 timing belt touches, should be a h22 component.
h22 crank gear, cam gear, modified water pump with an h22 gear....
asianpoet is offline
Old 04-01-2013, 10:23 AM
  #788
Is the write up gone?
komodomoe is offline
Old 05-24-2013, 12:29 PM
  #789
BeastlyB's Avatar
Icon2 Re: New Frankenstein Engine = G23 (F23/H23 write up, Long, 56K beware)
wow it is gone...
That saddens me as I am trying to learn stuff as much as possible.
Help seems to be difficult to find.
BeastlyB is offline
Old 02-20-2014, 08:05 AM
  #790
BIG T's Avatar
does anyone know where this original post can be referenced it seems like pirate is the go to for G23 info
BIG T is offline
Old 02-26-2014, 08:09 AM
  #791
prelittlelude's Avatar
Originally Posted by PirateMcFred View Post
It's too bad those profiting off of content provided to their site for free don't appreciate the service.
Hey clear you damn inbox so i can messege you ;P
But seriously, send me a PM with your email, we need to catch up!
Others see my F22/H22 thread to see the update on my prelude
prelittlelude is offline
Old 02-26-2014, 09:09 AM
  #792
Katman's Avatar
if anyones interested and in the S.CAL area, I gotta F23 longblock and k20a2 pistons for sale.
Katman is offline
Old 02-26-2014, 09:58 AM
  #793
PirateMcFred's Avatar
Done.
PirateMcFred is offline
Old 03-03-2014, 08:39 AM
  #794
BeastlyB's Avatar
Could you please repost the write up.
I have been reading the whole thread and gained some knowledge but would greatly appreciate reading the rest.
BeastlyB is offline
Old 07-01-2015, 06:13 PM
  #795
Hey there, am new to this forum, have been doing some research on the "G23" build and can not find any definitive info on how to time the engine. I have an H22 crank gear but can not find any info on if it needs to have the timing location modified or install on the same key way as the F23 crank gear. any information would be great
enginehead is offline
Old 07-01-2015, 06:16 PM
  #796
do you have to modify the H22 crank gear and have a new key way cut in it or do you put the factory key way on the F23 factory crank key way? do you use the same factory timing marks on the block?
HERN39
01-12-2016 07:07 AM
dipi131
12-27-2015 09:53 PM
Pinja
General Discussion and Debate
65
11-21-2015 07:38 PM
qualitytrans
10-12-2015 02:16 AM
loya15
07-13-2015 05:09 PM
Quick Reply: New Frankenstein Engine = G23 (F23/H23 write up, Long, 56K beware)
  • Ask a Question
Question Title:
Description:
