need engine connector pinouts
hello i am looking for pinouts for the shock tower connectors ; c133, c134, c135 m/t, and c136 i have only found limited info maybe some who works at honda could help me out i have a shop manual but it doesnt tell me pinouts and neither does alldata or mitchel on demand i am in desperate need of this info thanks in advance!
Re: need engine connector pinouts
it is a 0bd1 also
Those are the connections that go into the cabin. c133 connects to C425, c134 to c426, c135 to c432 and c136 to c433.
yes i need to know where the wires go from those connectors. i am doing a h22 crx im using a dash wiring harness from a prelude and i shrunk it down to just the data wires going from the ecu to the engine i just have wires that dont go to the ecu that im guessing either go to power or ground for sensors i have about 12 wires that go to those connectors but not to the ecu and i need to know where they go.
if u look up in the manual about those connectors youll be able to get the pinouts.
ok if you give me the wire colors and what connector they are from i can tell you where they go.
ok thanks give me like 3 seconds
k blue connector not engine side and blu/wht, yel/blk, yel/red, blu/red, blk/yel, yel/wht, and red oh and just strait blue too
which connector is that? c###?
c136 i believe would this be easier over the phone?
Originally Posted by teamredline9k
(Post 44880021)
the red wire is the ect gauge sending unit. blue wire goes to the dizzy its either tdc/ckp/cyp( its part of the two wire connector the other wire in the connector is a thick yellow wire) Yellow/white is one of the wires in the tps blk/yellow goes to the junction box in the bay yel/red is oil pressure switch yel/blk also goes to the junction box blu/white i dont have a blu white...i have a white blu in that connector which is part of the alternator. hopefully this helps a little |
anything helps are you using a manual? if so would you be able to fax or send pics or post pics?
i have a torn apart harness that i took apart and labeled everything. Was working on it last week havent finished yet. I got some more answer hold up
that single blue wire actually goes to the distributor coil i believe. I have an external coil
ok can i pm you my number and text or call or somethin?
pm'd
