My window is Stuck
well my window is stuck on my 1994 Honda Prelude SI. I dont know if the motor is burned or if its just stuck... anyone know how to get the window up w/o power cuz its rolled down and its getting to be winter... I dont want my interior ruined lol http://images.honda-tech.com/set1//smile/emcrook.gif https://honda-tech.com/forums/images...es/emdgust.gif
Re: My window is Stuck (JDM custums)
your motor could possible be out or your window may be off track
If it's your passenger window, make sure your master switch on the driver door is 'ON' before you decided to dismantle the door. Yes, this is experience talking. https://honda-tech.com/forums/images...s/emhammer.gif
k ill look at both thx guys if not then ill repost here
Re: (JDM custums)
Most likely the window regulator (a mechanical mechanism that looks almost like a large pair of scissors inside the door) is just clogged up with dirt and needs cleaned. Remove the door pannel and lift off the glass...can be pushed up from the bottom and then hold it up with a piece of wood or some sort of spacer. Then disconnect the regulator from the motor and operate it by hand...clean were they join and then lube and reinstall...then plug in the harness (before you reinstall the panel) and check to see if it operates again.
Cheers! |
Re: My window is Stuck (Lewdin' Incognito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewdin Incognito »</TD></TR><TR><TD CLASS="quote">If it's your passenger window, make sure your master switch on the driver door is 'ON' before you decided to dismantle the door. Yes, this is experience talking. https://honda-tech.com/forums/images...s/emhammer.gif</TD></TR></TABLE>
this was my first thought as well... I too speak from experience!!! https://honda-tech.com/forums/images...s/emhammer.gif |
i have a similar problem..
my dr. side window seemed to hav ADD when i 1st got the car && u had to play with the switch to get it to go up/down.. but as of 2 days ago, the window just quit on me period.. some electrical guy looked at it && said it might be the alarm or something [seeing as that when u lock the car w/ the remote, the dr. window should go up, but doesnt, due to the ADD] .. I have search plenty of forums && many ppl have window problems but no one knows how to fix themm.. grr... |
frigen stupid huh.. well imma just put the window up manually like cidgrad130 told me how to then just let it sit till i can put money into my car..
well i managed to get my window up... but i realized its kinda off track lol so ill have to fix that when i get a chance.... but now i have a really stupid ass problem... when i stick my key into the lock it doesnt move lol wtf
Same problem on mine.
Two fault on my windows: 1. Left side: brushes in liftengine is worn/no contact, no response. 2. Right side: Needs cleaning and lubrication. |
lol sux huh... i need to figure a way to frigen get my window back on track lol... i had to tape the top of the window cuz of rain lol
