Location of Factory Foglight Harnesses in 92 Prelude Si??
Hey Guys,
I bought a set of JDM Foglights w/ a switch... I've looked up installation instructions for the Prelude's factory wiring harness... The instruction were meant for the '94-'96 Prelude's... They were still very helpful, but not perfect... http://images.honda-tech.com/set1//smile/emcrook.gif In the '94+ 4th Gen. Prelude's the foglight switch harness is located in the center console underneath the cupholder, but this is not the case with the '92-'93 Prelude... I converted to a '93 Center Console, so I've seen everything under my center console... Where is the Factory Foglight Switch Harness located in a '92 Honda Prelude Si? In the '94+ 4th Gen. Prelude's the foglight relay harness is located under the steering column, but I'm not sure if this is true for the '92 Prelude... I haven't checked yet, so I figued that I'd ask before I took my car apart again... Where is the Factory Foglight Relay Harness located in a '92 Honda Prelude Si? Thank You in Advance! https://honda-tech.com/forums/images/smilies/emthup.gif Peace https://honda-tech.com/forums/images...es/emsmile.gif Modified by illude9357 at 8:07 PM 5/10/2005 |
