jonathan2006's '94 Prelude Si
#26
Re: jonathan2006's '94 Prelude Si
Yellow(SRS) plug is for air bag
Grey(OBD1) plug is for retrieving DTC
Forgot what the blue one is for( not 100% but i recall it being for ABS )
But their supposes to all be like that. Those are access ports for a scanner basically.
#27
Well I plugged a loose yellow one into the other yellow one. I'll unplug next time I'm I go to work on it. I haven't started driving it yet.
#30
i scored an accord rear lip at the junkyard today for about $12. i grabbed the rear mud flaps while i was at it. do accord mud flaps fit? also i picked up some speakers at bestbuy.
#31
i finally got my function and form type 1's today. i bought them a few weeks ago off preludeonline.com.
lol i totally forgot about how i had to rig my brake light plug with a penny to keep my brake lights from staying on. i still cant believe this actually worked and has been working for awhile now.
i assassinate abe everyday
#32
i got a couple of things tackled this weekend. function and forms got put on and i cut the lip to fit. its not perfect because i think i need the coupe but i think i did a pretty good job. the mud flaps fit too. i also replaced the tailight, but i need a new bulb. i went ahead and put my motegis on it as well.
here are a couple of before shots
i got a little surprise when i took the bumper off
here is a before of the lip
the muffler part is where it doesnt really fit right
after
here is the black emblem on the front
other then the stuff i have on the way i need a passenger axel and prob a rear bushing
after
#36
well i got my other stuff a few a weeks ago but i havent had time to post. i got this stuff super cheap and just couldnt pass it up.
aem v2 intake - used as a display so pretty much brand new. my factory system was broke and most of it was missing.
wasnt sure what to do with the extra hose that goes from the tb to the idle control box, so i put a cap on it. is this correct or does anyone have any suggestions?
looks so sexy and sounds amazing when you get on it
DC header - i will hopefully be putting on this weekend. i also went ahead and got a cat delete pipe as well.
also a very important tip - dont forget to remove all tools from under the hood before driving home
#41
on saturday my brother and i went on base to install my dc header/cat delete pipe. unfortunately my car was too low for one lift but i was able to use other type of lift. the old header and cat were done and were so rusted we almost couldnt get them off. i was not able to retain my o2 sensor so i am in need of a new one and i will probably order as soon as im done here. on my way one something came off because i have a nice leak and my car sounds terrible now. i know my cat pipe has a place for a sensor but its plugged. the downpipe is where my sensor goes and it had a plug in it as well, but i dont think it was secure. my dad and i torqued and checked all the bolts yesterday and i totally forgot to check that plug on the downpipe. so for right now im beastin it till i get a new sensor in.
i searched alot of parts stores for this gasket and still had to order it online
my torn axle
goodbye cat converter
im still not sure if im gonna keep the tow hook or not
Happy Halloween
my torn axle
Happy Halloween
#42
small update:
i got a denso sensor but both connectors are female. i went ahead and put the sensor in to plug the hole and cure my exhaust leak, but i need a male connector to wire in and connect to the main harness.
i splurged alittle and bought a Bride boot. i also got my Team Voodoo **** out of my civic and put it in the prelude since i havent gotten to try it yet. right now i dont have the boot fastened down with anything. the stapler i have wont go through the plastic.
my crank pulley broke the week before last. the nite before the powersteering quit and i thought i was just the belt. i drove it to work the next day without issues until it was time for me to go home. started it up and all i heard was clank clank clank. the pulley separated from the harmonic balancer. i picked up a Ralco set and now the prelude is back on the road.
#43
UPDATE:
since i dont smoke i drilled a hole in the back of the ash tray for the alpine ipod cord
i got a flat
the spare just happen to be flat too
i put the blades back on for now
i got an Apexi Megaphone Dunk muffler from a buddy and had APE put it on yesterday. it almost didnt fit cause it was pretty big, but with alitte custom piping they got it to fit. i made a short video this afternoon and put a link at the bottom of this post.
some random pics
http://youtu.be/GLd4gYkQVfg
i got a flat
some random pics
#44
Do some research, those aftermarket crank pulleys are bad, there's a reason why the OEM one is a certain weight and diameter. The solid metal structure of the aftermarket one could also cause more harmful harmonics.
This is the only one I'd go with
http://www.atiracing.com/products/da...s/damhonda.htm
#47
i might since i need to pull it off and replace a broken stud
thanks
i know it really does suck cause i have a set of work emotions and buddy clubs i could put on it
