JDM h22 Type-SH swap. Bad gas mileage. - Page 2 - Honda-Tech - Honda Forum Discussion
Old 11-20-2018, 07:45 PM
  #26
Default Re: JDM h22 Type-SH swap. Bad gas mileage.
For my Type S conversion of my SH, we swapped out and used the USDM oil pump and the JDM Dizzy.
When I ran the USDM SH ECU on my Type S conversion, it leaned out and warped the head.
Since then, I've machined the head and I've been using a p28 chipped with a h22a Type S basemap, which means two things:
1) I cannot pass smog (non-obdII -I'm in CA); and
2) I temporarily have no ATTS
Ideally, you would use the JDM ECU since the engine is higher compression and has different timing (ideally, you'd also be using spark plugs with a shorter gap).
As for a solution, I am currently and partially in the same boat: how do I run this engine properly without misfire, stay OBD2 compliant, and keep ATTS.
My guess while still actively trying to research this is to use the USDM ECU with a piggyback to control A/F, but I've been seeing mixed reviews on piggybacks.
This has not been the easiest swap at all because of the ATTS and, if you're in CA, stringent smog laws.
sayten07 is offline
Old 11-20-2018, 09:18 PM
  #27
basicly Type S swap is out of the question if you cannot use JDM ecu which came with it
so answer is: move out ot CA or just do complete JDM swap - no USDM electrics
TimiK is offline
Old 12-15-2018, 04:23 PM
  #28
I own an actual JDM Type S Prelude and get about 24 MPG running Shell V Power, and that's hitting VTEC multiple times on the daily. It's bone stock other than I removed the resonator butterfly and piping behind the front fender. Still running the stock air box and Type S intake.
dirtysohc is offline
Old 12-17-2018, 06:19 PM
  #29
You need to post a pic or two!
UserNameInUse is offline
maintain
05-20-2008 09:51 PM
b18LS
08-17-2007 03:10 PM
bossman032
04-01-2005 02:04 PM
Quick Reply: JDM h22 Type-SH swap. Bad gas mileage.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
