JDM H22 Crank Posistion Sensory bypass help
Car: 99 Prelude base model. 5 spd, blown engine. USDM ECU.
Motor replacement: JDM H22 (no crank sensor) My question is how to bypass the sensor. I have been reading up articles on how to bypass it on Civics/integra but haven't found any useful info on 97+ Prelude Any info would on how to bypass this would be GREAT! Thanks! |
Re: JDM H22 Crank Posistion Sensory bypass help
You can't bypass it, the sensor on the JDM engine is inside the distriubutor, you either have to rewire or swap your old distributor, external coil, oil pump, ckp sensor and lower timing gear over from the old engine.
Correct, there is no extra sensor to bypass like with Civic/Integra.
Originally Posted by minilogoguy18
(Post 47127039)
