injectors and plugs
could someone please clear up what exactly i need to purchase along with a new set of injectors......
i have AEM EMS......so went with the saturated rc 650s, (SL4-650)....into a 99 honda prelude.....what plugs /connectors do i need, or can i just hard wire everything.. also i was told with my new EMS, resistor boxes and such arent needed... |
Re: injectors and plugs (prelude994e)
What is your setup?
Re: injectors and plugs (SKDRCR)
i didnt think my setup mattered but
fully built bottom end h22 DRAG gen 4 turbo kit AEM EMS AEM fuel rail AEM FPR Walbro 255 fuel pump |
the Aem Ems is probably an overkill for your setup
but it will do the job just fine for you. I hope you have a good tuner to tune it because they're not that easy to tune. |
Tou don't need a resistor box and can't have it as a matter of fact with saturated injectors
over kill...... i dont think so man................im runnign 17psi, on 650cc injectors with 8.3:1 compression pistons(no cam gears or ignition) and spraying...to somewhere btw 350-400 whp....i NEED the EMS for fuel and timing issues, i dont want to do a little piggyback thats gonna hold me back....
haha AEM is over kil if you have like I/E/H....then maybe...i could see that AND: no one commented on the plugs, do i need some for my injectors |
| All times are GMT -8. The time now is 08:43 PM. |
