Igintion lock cylinder
Re: Igintion lock cylinder
there is a screw you need to remove that locks it into place, then you need to have the key in a certain position, normally the 1 position, but you can check the new lock cylinder and you will see where it needs to be, then you need to push in the pin that's in the hole in the steering housing that pushes in the pin in the lock cylinder and then just pull out the lock cylinder
Kipper-Fish
11-27-2008 09:17 AM
bsclywilly
Audio / Security / Video
06-02-2007 08:33 AM
