Air Condition problem 98 Prelude.
Old 06-23-2008, 01:41 PM
jack_yaj's Avatar
Default Air Condition problem 98 Prelude.
I have a 98 Honda Prelude. Today I turned on my A/C and found out that my A/C doesn't work until it's on high. I checked the fuses and they're fine. I tried checking the cooler fan system but I have no idea how that thing works. Any ideas how I can solve this issue???
Thank you,
Jack Yang
Old 06-23-2008, 01:57 PM
dixxon's Avatar
Default Re: Air Condition problem 98 Prelude. (jack_yaj)
if the fan doesn't turn on until you put it on high either then i believe the blower motor resistor is the problem. same thing happened to me on my 92 SR.
#4 in the illustration:
can someone else confirm this?
Old 06-23-2008, 03:07 PM
DrivinVtec's Avatar
mine does this too. heat and ac. been doing since i own the car.
Old 06-23-2008, 05:27 PM
dixxon's Avatar
Default Re: (DrivinVtec)
thats for sure your blower motor resistor then.
Old 06-23-2008, 06:47 PM
JBirch_97Prelude's Avatar
Default Re: (dixxon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dixxon &raquo;</TD></TR><TR><TD CLASS="quote">thats for sure your blower motor resistor then.</TD></TR></TABLE>
Agreed! Had the same problem with my Integra. Simple fix!
Old 06-23-2008, 09:45 PM
jack_yaj's Avatar
Default Re: Air Condition problem 98 Prelude. (dixxon)
Thanks a lot Dixxon!!! I'll check it out tomorrow morning.
Thank you,
Jack Yang
Old 06-24-2008, 04:49 AM
DrivinVtec's Avatar
expensive part? easy to get too?
Old 06-24-2008, 10:02 AM
jack_yaj's Avatar
I found a few on ebay and you can check your local autozone shop. On ebay it sells for 26 dollars and on autozone it goes for $33.99
Old 06-24-2008, 10:38 AM
DrivinVtec's Avatar
is this under the dash on the passenger side?
Old 06-24-2008, 11:50 AM
jack_yaj's Avatar
Yeah, it's under the passenger dash to right.
Old 06-25-2008, 12:36 PM
DrivinVtec's Avatar
is this what i need?
http://cgi.ebay.com/ebaymotors...ZWD1V
Old 06-25-2008, 06:02 PM
dixxon's Avatar
yuppp
Steve LeB
Honda CR-V & Element
10-19-2016 10:05 PM
mrlover
12-31-2007 07:33 PM
Quick Reply: Air Condition problem 98 Prelude.
