HOW TO: Remove Power Steering and Loop the lines
Old 05-14-2007, 03:13 PM
  #26
LukieLuc's Avatar
Default Re: (117)
is this the same thing for the 4th gen preludes?
LukieLuc is offline
Old 05-14-2007, 03:38 PM
  #27
mgags7's Avatar
its all basically the same thing
you're much better off converting the whole thing to manual.
mgags7 is offline
Old 05-14-2007, 03:55 PM
  #28
LukieLuc's Avatar
Default Re: (mgags7)
The attachment will fit in my rack?
LukieLuc is offline
Old 05-14-2007, 04:26 PM
  #29
mgags7's Avatar
Default Re: (LukieLuc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc &raquo;</TD></TR><TR><TD CLASS="quote">The attachment will fit in my rack?</TD></TR></TABLE>
what attachment?
mgags7 is offline
Old 05-14-2007, 05:36 PM
  #30
Shadowz7429's Avatar
gonna give this a go
Shadowz7429 is offline
Old 05-14-2007, 06:18 PM
  #31
LukieLuc's Avatar
http://i23.photobucket.com/alb...5.jpg
This attachment will it fit y 4th gen rack, if not how would i loop the lines?
LukieLuc is offline
Old 05-14-2007, 06:33 PM
  #32
mgags7's Avatar
You can find a fitting that will work
Converting your rack to manual doesn't involve looping the lines at all, I think you're confused.
mgags7 is offline
Old 05-14-2007, 06:44 PM
  #33
LukieLuc's Avatar
i basically want to get rid of my PS, by looping the lines; im trying to figure out how do i loop the lines, do i need any connectors, or fittings like he used? Or can i just cut and loop them? sorry for all the ?'s im new to this DIY thing lol
And as in loop i mean the "In line" to the "out Line" in the steering rack, i am not looking to do a manuel steering rack conversion at this time, but maybe in the future. I am not that savvy yet to do it, and looking for the easy way out
LukieLuc is offline
Old 05-14-2007, 06:48 PM
  #34
mgags7's Avatar
you use fittings and then loop lines btw them.
mgags7 is offline
Old 05-14-2007, 07:08 PM
  #35
LukieLuc's Avatar
oh okay thanks
LukieLuc is offline
Old 05-14-2007, 08:07 PM
  #36
ZakkWylde's Avatar
How do you get through state inspections without power steering? I took mine out then I had to get it inspected and failed because I took P/S out. Maybe it's just the state I live in?
ZakkWylde is offline
Old 05-15-2007, 03:26 AM
  #37
LukieLuc's Avatar
Default Re: (ZakkWylde)
I usually go to the shitist garage i can find, that do inspections, than i pay of the guy about 50 bucks to run his car on the dyno instead of mine thats with the price of inspection included in the 50. By the time they finish that they dont check anything else lol
LukieLuc is offline
Old 03-31-2008, 06:01 PM
  #38
95greenlude's Avatar
Default Re: HOW TO: Remove Power Steering and Loop the lines (98vtec)
i'm going to add in what to do with a 4th gen....just because the racks are different and you have to account for the Power steering speed sensor
95greenlude is offline
Old 03-31-2008, 06:04 PM
  #39
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZakkWylde &raquo;</TD></TR><TR><TD CLASS="quote">How do you get through state inspections without power steering? I took mine out then I had to get it inspected and failed because I took P/S out. Maybe it's just the state I live in?</TD></TR></TABLE>
in pa ive looked through the inspection book and couldnt find anything that says its not legal.
lude98SH is offline
Old 04-02-2008, 11:38 AM
  #40
shaggyeg6si's Avatar
Default Re: (98TypeSH)
Everyone please understand that there is a difference from just cutting the belt, to looping the lines. With the belt cut, you know have to work past all the fluid and force it around. It's more difficult without the belt, than if you were to have your fluid lines looped.
shaggyeg6si is offline
Old 04-18-2008, 09:14 PM
  #41
Acidcrakker's Avatar
Default Re: HOW TO: Remove Power Steering and Loop the lines (95greenlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude &raquo;</TD></TR><TR><TD CLASS="quote">i'm going to add in what to do with a 4th gen....just because the racks are different and you have to account for the Power steering speed sensor </TD></TR></TABLE>
Id like some more info on this.
Acidcrakker is offline
Old 04-18-2008, 09:26 PM
  #42
dagle's Avatar
Default Re: HOW TO: Remove Power Steering and Loop the lines (Acidcrakker)
ooh glad i read these 2 pages, to add to the low speed parking lot situations, it really helps to use a smaller diameter steering wheel. As counterproductive as that may sound (smaller circumference equaling to requiring more force to turn) the majority of the difficult is the awkwardness of the muscles you use. cuz i noticed in my old prelude w/ belt off that when i needed to turn at no speed, i only yanked at the one side. so a smaller wheel will just get more done w/ the same movement. (the 1 yank) because for damn sure there was no way i was gonna be using my shoulder in a side to side motion.
good stuff, but definately not for me since i love steering w/ 1 hand (other hand on shifter) even for parking.
dagle is offline
Old 04-24-2008, 12:30 PM
  #43
Default Re: HOW TO: Remove Power Steering and Loop the lines (dagle)
for a 4th gen:
everything is basically the same....the only thing that is different is you have a couple of extra hoses to remove, and looping the lines is different.....
power steering speed sensor.....
i used the smaller rubber line that goes to it.....
and this is how i looped the steering rack, the barb fitting is on the very right
i went to autozone and picked up some 3/8" trans. cooler lines.
Old 04-24-2008, 02:10 PM
  #44
So you looped the VSS together?
ALso I had my Power Steering Belt off for better part of a week, and something started minorly grinding. IDK what it was, but it stopped when I put the belt back on. Any thoughts or IDeas on that one.
Old 04-24-2008, 02:13 PM
  #45
just follow the power steering lines to the sensor, you will see which lines to loop
Old 04-24-2008, 02:23 PM
  #46
Im gonna draw a diagram a retard could understand later for the 4th Gen Loop. Ill post it up and you could take a look at it for me, it would be great.
Old 04-24-2008, 02:31 PM
  #47
there should be no diagram nescessary.....its pretty cut and dry
Old 04-24-2008, 03:44 PM
  #48
russlan44's Avatar
i might do it, first take off the belt, drive for a day or two then see if my wife can drive it and ill look the lines, by the way you guys say it, sounds easy.
russlan44 is offline
Old 04-24-2008, 08:24 PM
  #49
Default Re: HOW TO: Remove Power Steering and Loop the lines (russlan44)
Okay heres my drawing. I should of said more like a retard drew it rather than a retard can understand.
So when removing Power steering does the PS. Resover and Cooler have to stay or can they all be removed?
When looping the lines, all you have to do is loop the lines off that connect to the VSS and Block off the other line that goes to the PS Pump. Dont you have to keep some PS fluid in there so the VSS can work, or is it not needed?
Im having a hard time trying to understand just what it is that needs to be looped here.
Old 04-25-2008, 11:21 AM
  #50
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Okay heres my drawing. I should of said more like a retard drew it rather than a retard can understand.
Okay so after re-readin 98vtecs original post I have a few questions.
1. The attachment fits on the steering rack is looped to the middle of the 3 lines on the steering rack.
2. The 1st and 3rd lines on the steering rack are looped together.
3. Make sure to top the steering rack off with PS Fluid it is needed.
4. Everything else is removed.
Sound about right.
JAred I really cant tell what your pictures are.
Quick Reply: HOW TO: Remove Power Steering and Loop the lines
