h23a1 transmission/h22a motor
^ should i have any problems with this combination?
if so, what kinda of problems.. would this motor be to much for the h23a1 transmission? |
Re: h23a1 transmission/h22a motor (shaylude)
I don't think so, just longer gears compared to the h22 tranny? Is it an auto or manual tranny?
Re: h23a1 transmission/h22a motor (Toe_Knee)
manual
naah, you shouldnt have any problems at all. it certainly isnt "too much" for the tranny, the only difference is the gear ratios. they are a little longer. i ran the same combination for over a year and didnt mind it at all.
Re: (syntax.)
only problem is you would have more top end and longer climbing rpm's (if that's a problem at all for u)
Re: (phatsindabuildin)
well i hope its gonna be a great combination!
Re: (shaylude)
get a better final drive for it tho
Re: (P13_mein)
My friend had that setup before he swapped to a H22 transmission. He swears he could have done 160... He said he was topping out the speedometer at about 5800.
Re: (no1knows908)
Same combo here, does fine, I like having a bit lower rpm on the highway so its fine with me, and still fast as crap! I do have a decent clutch in mine, and recommend while in there check flywheel/ clutch etc, and relube well!
Re: (snobordboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P13_mein »</TD></TR><TR><TD CLASS="quote">get a better final drive for it tho</TD></TR></TABLE>
why would i need to do this? what would be the advantaged of it. and how much would i cost? |
Re: (shaylude)
The only "disavantage" is that the gearing is a little longer, so you'll drop out of VTEC when you shift.
Re: (Finest)
i see..
