H23 to a H22
What is needed? The H22 is a obd2 while the H23 is OBD1 so what will this consist of?
Re: H23 to a H22 (1_slo_92)
are you serious???? just get a obd2 to obd1 harness, and use h23 ignition system
and btw, search! |
Re: H23 to a H22 (petern101)
Well what is the harness? The engine harness, or the harness inside of the car?
He is asking how to run an OBDII engine in his 4th gen.
Re: (Daboi630)
well he can swap in a whole obd2 engine and use that harness to switch it to obd1, i'm sure this has been covered before
i mean the 96 prelude was 0bd2, he could just copy that setup (although that ecu is very rare) if you swap everything over its not too bad |
