H23 crank pulley
I was wondering if the crank pulley off of my stock H23 would fit on my H22A engine? My H22 pulley was damaged in shipping so i need to swap it out. Thanks https://honda-tech.com/forums/images...es/emsmile.gif
Re: H23 crank pulley (Sabbotage)
yes, but you'll need the H23A's other pulleys also. And you must use a H23 belt (of course).
Re: H23 crank pulley (Kal)
sweet! I have all of them too so thats not a problem. I'm starting my swap tomorrow so it should be fun. https://honda-tech.com/forums/images/smilies/emthup.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sabbotage »</TD></TR><TR><TD CLASS="quote">sweet! I have all of them too so thats not a problem. I'm starting my swap tomorrow so it should be fun. https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE>
best of luck to you bro, let us know if you come across any problems https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: H23 crank pulley (SKDRCR)
yeah i'll do that. Im sure ill have to ask a few questions but ive done a few easy swaps before so im hoping i dont run into any problems. The hardest part i think will be the wiring from the old to the new motor with VTEC and all. I'll get through it im sure https://honda-tech.com/forums/images/smilies/emwink.gif
Yes, you can. One of the belts has an extra groove compared to the other car's, but it may work depending on which one it is.
