h22 problems
alrite my car, its a swap and it is running like shit and my rpm gauge is messed up when i try to go over 4500 then it starts to spudder and when i go 2 start it from a cold start it starts but when i give it gas it like cuts out would any body know wat is wrong wit my car please get back to me thank you..
Re: h22 problems (fastnnasty06)
make sure your timing is right...my cams were off by like 1tooth and it messed it up EXACTLY like you discribed...I set my cams right now and its still doing it some. https://honda-tech.com/forums/images...s/emthdown.gif
Re: h22 problems (WhiteBB2)
alrite thank you i will try that oout should i just buy new cams or wat? and a timing belt? cause i wanna get this running better for the spring time
| All times are GMT -8. The time now is 05:21 PM. |
