H22 issues. Misfire!
#26
Re: H22 issues. Misfire!
Same problem. Injectors are brand new and full functional, new cap, rotor plugs and wires. 94 eg hatch with jdm h22a4 obd2, buddy was driving it and went from 3rd to 2nd gear and the car screamed and now it has a misfire on cylinder 1, full stage 2 Brian crower engine from valve cover to oil pan. We replace all ignition and fuel supply after that incident and still misfires on 1. Any suggestions?? Sct tunes ecu, and timing is all right but maybe the cam gears or belt skipped a tooth or so? Please help
#27
#28
this is just bad time for our h22. I am having a miss fire in cylinder number one as well. stock block, with a t3/4 turbo, hondata s300, 440rdx injectors. fuel pressure regulator. new plugs, wires, i put in a 450lph walbro and ever sense it has had a miss fire that i can not get ride of. at first it was only spitting and sputtering in the top end, but now sometimes i simply have no fire from that cylinder. injectors are good and I have spark to the plug. i have had this problem for a while.
ShowSi2
12-09-2003 05:27 PM
