Fuel Gauge!!
I have a single gauge pod for my 4th gen lude for a fuel gauge and was wondering what all i should take off to hide the wires. Any suggestions would be great!! https://honda-tech.com/forums/images...es/emsmile.gif
Re: Fuel Gauge!! (jdmh22luda)
um...you should take off what's in the way. What's wrong with your stock fuel gauge? And learn to title your posts, please.
Re: Fuel Gauge!! (The Phil)
its an air/fuel, im hooking up my vafc and want to make sure its not running lean https://honda-tech.com/forums/images...s/emsmileo.gif
air/fuel gauge will not work right unless you have a wideband o2 sensor plugges into it. stock sensors are not wideband.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmh22luda »</TD></TR><TR><TD CLASS="quote">its an air/fuel, im hooking up my vafc and want to make sure its not running lean https://honda-tech.com/forums/images...s/emsmileo.gif </TD></TR></TABLE>
just get it tuned then you wont have to worry about it. besides that A/F gauge is nothing more then a pathetic light show. however if you really want it, take the a pillar plastic off. drill a hole in it, attach the gauge pod over the hole and then put the wires through it. if you couldnt come up with that on your own, maybe you shouldnt be working on cars http://images.honda-tech.com/set1//smile/emcrook.gif |
