FS: Neuspeed FRONT Swaybar for 97+ Prelude
Re: FS: Neuspeed FRONT Swaybar for 97+ Prelude (mike2016)
Yes they do. You can find it for sale at http://www.carparts.com or http://www.nipponpower.com.
Why would you want one though? Yes please, I would like some more understeer... Im sure it would keep the front from swaying much though...
Re: FS: Neuspeed FRONT Swaybar for 97+ Prelude (Honda318dx)
You would want one so that you can match it up to a Neuspeed rear bar, and have a great suspension set-up.
Re: FS: Neuspeed FRONT Swaybar for 97+ Prelude (girlRacer)
Not completely sure on this one......most go for just a rear bar to induce a bit of oversteer, but fitting a front one just as agressive may negate the effect......make sure you can return it if not happy....
New User
changing both, if they are properly matched, should keep the same general amount of understeer vs oversteer. If you want to improve on the amount of understeer you should just change the rear. Doing both should pretty much eliminate body roll, but it won't do a lot for your handling characteristics, ie still understeer the same.
Re: FS: Neuspeed FRONT Swaybar for 97+ Prelude (Jarrad_r6)
Doing both will eliminate both body roll and induce more oversteer. Stock sway bar sizes are 25mm front, and 23mm rear. Neuspeed bar sizes are 28mm front and 28mm rear. As you can see, the rear will be beefed up more than the front.
lOOkatme
07-30-2005 05:54 PM
