F22b2 block+H22a1 head, F22 VTEC, F22B/VTEC
#2026
Re: (prelittlelude)
EDIT: i took the big pics down, all the links are still there, i don't know how to make thumb nails, and big pics are killing the server
on the previous page you can see the oil cooler setup, where it screws in the block, i just took the plug that was in the f22 block out, and then screwed in the nipple from my h22 block, and then hooked up the line
heres how i did the first custom plug, just bought a 3/4 inch bolt nd used a grinder to make a spot for the oring to sit, i decided to go the plug method after i realized that i would never find a tap for a 20mm hole, or a 18mm hole which the 2 oil drains that needed to be pluged are. still need to finish making the plug for the 18 mm hole, just need to grind it and press it in
http://the.ne.client2.attbi.com/userT/plug.jpg
here is the old h22 water pump bearing body, and the pully from the f22 pump and the pully puller i used.. if you look at the pics its just a pressed on pully to a shaft
http://the.ne.client2.attbi.co...1.jpg
http://the.ne.client2.attbi.co...2.jpg
and here is the f22 pump body with the P13 h22 pull pressed on (used a vice and wood and a socket) seriously it says p13 , ****** pics
http://the.ne.client2.attbi.co...3.jpg
here is the motor with most of the timing belt assembly on it, note lower h22 timing gear already instaled
http://the.ne.client2.attbi.com/userT/motor1.jpg
then a shot of hopefully you can make that out , it says F22B2,
http://the.ne.client2.attbi.com/userT/motor2.jpg
then a zoomed out shot
http://h00045a28953c.ne.client2.attbi.com/tom2.jpg
and then here is the reason you have to change the belt in the first place h22 belt on the left, and f22 on the right
http://the.ne.client2.attbi.com/userT/belt.jpg
here is a good example of why the oil drains need to be pluged, no gasket material anywhere near by
http://the.ne.client2.attbi.com/userT/oil.jpg
and then here is the motor freshly deck 35 thousanths, with my AEBS head studs, awaiting a head gasket.
http://the.ne.client2.attbi.com/userT/ready.jpg
well i have more pics, if you guys are interested let me know, or if you have any specific questions, i can clarify
Modified by prelittlelude at 9:09 PM 3/8/2004
#2027
Re: The cats out of the bag: F22b2 block+H22a1 head (prelittlelude)
#2028
Re: F22b2 block+H22a1 head, F22 VTEC, F22B/VTEC
Looking for someone in southern California to build me a frankenstein engine ..... Dont really have too much free time of my own ..... Hit me up I'm very serious to get this going .....
