Euro r H22A with PCD install
#26
Re: Euro r H22A with PCD install
I know when I did my swap I had a hesitation issue too until I realized I need to use shielded wire for the knock sensor. It was the weirdest hesitation issue I have ever tried to diagnose and I spent literally months on it til I finally bought some shielded wire and wired it up and it ran perfectly after that. I don't know what kind of shell you're using or if your knock sensor wire is factory shielded. Just thought I'd throw this out there. What was happening was that I was using a single unshielded wire and it was picking up radio interference on its way to the ecu and I was getting my ignition timing screwed up in the 2-4k rpm range. After 5k it stops using the knock sensor input.
#27
Yes, I drove it. My install hesitates a bit for the first couple of blocks until it gets good and warm, but after that it takes off like a rocket. Egr didn't change any hesitation though. I just did that because it occasionally threw a code. You might read my iacv wiring again, I rewrote it to be clearer. My other thought would be clean the throttle body and run injector cleaner through it if you haven't yet. Seafoam is the best for the injectors.
#28
Don't think the jdm ecus use the kknocksensor holmsnmanny. Good info though, never would have thought to check that on one.
#29
#30
Some don't use the vtec pressure switch. If the engine has a knock sensor then it obviously uses the knock sensor input. Unless that engine doesn't have a knock sensor it will definitely use the input.
#31
Yes mine came without the vtec pressure sensor, but I put my A4 one in from my old engine and my euro-r uses the knock sensor I am 100% because I double checked to make sure it was plugged in.
#32
Pull the egr connector and let it run with the egr code on and see if the issue subsides. If it does, you know you're on the right track.
What harness are you using ? Do you have a shielded wire for your knock sensor ?
#33
Okay I will try to unplug the egr valve and see what happens. I am running the usdm obd2a engine harness with the rywire obd2a-obd2b jumper. The car runs very well and idles perfect. It just has that slight hesitation in 1st gear, but it only occurs sometimes not always.
#35
yes its safe to say I do have a p13 chassis. Also here is the knock sensor plug/wire I have no idea if its shielded like you were referring to or not.
#37
Yes its factory wiring, so I guess I am good to go thank god. And today I will be testing the egr issue out. If I unplug the egr and my issue is resolved with the slight hesitation what do I do from there? Buy and use the euro-r egr or what?
#39
Yes sir I did clean out the EGR ports but it was half *** cleaning I didn't buy new plugs and drill/slide hammer the old ones out. I just took the EGR off and cleaned everything I could see and used a pipe cleaner as far as it would reach. I am assuming I need to do it the right way and buy the plugs?
#41
I pulled the connector off my egr and nothing happened, no code thrown or anything so I am confused does this mean my egr is bad or what? I am lost right now.
#42
I believe it takes a couple drive cycles for it to throw a code. Run it a few times first with the connector unplugged. When it throws the code see if it drives fine after that.
#43
Okay I will try driving it for awhile and see what happens. If it runs better with it throwing a code does this mean I have a bad egr or clogged egr ports and need to clean them?
#45
well the check engine light finally came on yesterday when driving, and I have to admit it drives a bit worse with the hesitation issue. I will try to clean out my egr ports, take out the plugs and put new ones in and see what happens.
#47
Yes my intake has the plugs on it I have checked to make sure they are there. I am just worried by cleaning the ports will it actually help or fix the hesitation issue at all. The weird thing is I noticed that the hesitation issue seems to happen worse when the car is at operating temp. And when it is getting warmed up the the issue is barely noticeable almost non-existent. Do egr valves ever go bad is that a possibility?
I also had the CEL return for the EGR while driving today, but it was plugged in so I am having the same issue as thericepatch who told me he later changed his egr just to get rid of the code, and it didn't help the hesitation.
#50
yes, egr ports and the valve need to be cleaned....egr valves rarely ever fail...they just get gunked up....if anything the lift sensor will go bad before the diaphragm fails
for the valve just use your fingers and press on the diaphragm to make it go up and down while you spray it out with carb cleaner..it would be best obviously to pull the intake manifold to get a good cleaning and to not allow anything to get into the head
