Wiring issues
Guys,
So I just purchased this 97 prelude SH. The power door locks don't work unless the ignition is on, neither does the dome light. The previous owner installed a bunch of strobe lights by himself and a lot of the lights in the car are messed up. What do you think he did to cause this problem and what can I do to reverse this? Thanks. |
lets see here, a list of potential problems/consequinces of installing strobe lights:
1)getting wayyy too much pussy 2)winning <u>all</u> the races 3)looking m4d p1mp y0 haha now, on a more serious note, your strobe syndicate probably shorted out a lot of wires while installing deh str0bz also, those things probably pull a lot of amperage, so i could imagine that the wiring harnesses and fuses made for the systems he tapped into could be fried due to being overloaded |
Start by tracing the wiring from all those funky ass strobes to find where his electrical tape/chewing gum wiring job is causing the problems.
Re: (FadeToBlack)
Thanks for the responses. I willl take a look at it over the weekend and update you.
Re: (RickeyJa)
My friend suggested that the accessory position of the ignition switch could be burned out. What do you guys think?
