DIY: H22A VALVE ADJUSTMENT
Old 04-28-2012, 04:28 PM
  #101
Default Re: DIY: H22A VALVE ADJUSTMENT
Why does alldata and mitchell on demand both say to use .009-.011 for intake and ..011-.013 for exhaust ?
holmesnmanny is offline
Old 04-29-2012, 09:19 PM
  #102
Really guys ? lol
Old 05-01-2012, 08:01 AM
  #103
Can someone with a stock 93-95 prelude vtec go out to their car and look at the sticker under the hood and tell me wut the valve lash specs are ?
Old 05-03-2012, 04:53 PM
  #104
Thank you for this. Looking forward to do my 99 Prelude.
Phan10ms is offline
Old 01-29-2013, 03:09 PM
  #105
Thanks for the DIY. I did mine and I think they're loose?
ngengok99 is offline
Old 01-29-2013, 04:57 PM
  #106
I live under a rock
spoolinlude's Avatar
Ehh, that doesn't sound normal. Check your clearances again. Gotta make sure the screw doesn't turn when you tighten the nut to lock it.
spoolinlude is offline
Old 05-02-2013, 08:50 PM
  #107
space cadet
Shakes's Avatar
Holy crap! I made this thing ten f*&%#ng years ago. I'm glad its still helping people out.
Shakes is offline
Old 05-03-2013, 06:40 AM
  #108
Moderator
snobordboy's Avatar
Hi Shakes!! Good info from way back then, so it has stood the test of time!
snobordboy is offline
Old 07-02-2015, 05:07 PM
  #109
I just finished a valve job, thanks to this good info. Guess u forget things over the years, haha.
Though I haven't put the valve cover back on yet. I did the job; hand-tightened down all the lock nuts while holding the screw steady, but do not remember how I torqued them to 14ft-lbs without moving the screw. Or was it once the lock nuts are hand-tightened, I can torque them from there without the screw moving?
backinblue92 is offline
Old 07-04-2015, 02:08 PM
  #110
One of those but honestly just getting it tight by hand will be fine, 14lb-ft is very small and I've yet to see anyone strip or break the adjustment screw by just hand tightening it.
You also need to recheck measurement after tightening, it pulls the adjuster up making the gap bigger. I tend to adjust it to have a lot of drag then tighten the screw and it tends to be perfect. To know perfect is to set a micrometer to the gauges thickness, lock it and put the gauge into the micrometer to know the right amount of drag.
minilogoguy18 is offline
Old 07-04-2015, 05:04 PM
  #111
ojasia's Avatar
Too tight and you lose the thin layer of oil trying to cool things off as well, to loose and you lose lift and it is making over excessive hard tapping contact resulting in parts being worn at a faster rate.
ojasia is offline
TouringAccord
11-14-2018 09:43 AM
masterkill455
11-30-2016 03:56 AM
wildoutwhitegsr
05-05-2016 06:41 AM
HeikDiesel
126
08-20-2015 10:37 AM
HondAcura
05-23-2006 05:59 PM
Quick Reply: DIY: H22A VALVE ADJUSTMENT
  • Ask a Question
Question Title:
Description:
