Differences between... (engines)
I need to know what differences there are on a AT H22A and a MT H22A. (if there are any)
And if I have a body with A/C and a motor that didn't have it before, can I just bolt on the A/C when I swap? |
Would have thought the difference was the transmission ? AT= Automatic transmission & MT = Manual transmission, not sure of the A/C.
Re: (britishlude)
yeah, but just wondered if there were any difference between the motor that is on a AT or a MT or you can use a AT motor on a MT tranny? (just change the clutch acce...)
Re: (Longitud)
Should be all the same buddy good luck!!! https://honda-tech.com/forums/images/smilies/emthup.gif
Re: (95 lude)
ya they should be the same...
i think the power is slightly different because of slightly different ECU tuning and different exhaust routing... but very minor differences. |
Re: (kablamo)
don't the automatic engines come with different spec cams?
Re: (H22Si)
Re: Differences between... (Longitud)
I don't know about preludes, but I remember for awhile
Ford Tauras's (maybe only the SHO's) with AT were tuned with an extra 5-10 HP to help keep up with th MT. They wanted people to not worry about performance if the bought the AT. |
Re: Differences between... (topless1967stang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topless1967stang »</TD></TR><TR><TD CLASS="quote">I don't know about preludes, but I remember for awhile
Ford Tauras's (maybe only the SHO's) with AT were tuned with an extra 5-10 HP to help keep up with th MT. They wanted people to not worry about performance if the bought the AT.</TD></TR></TABLE> dont we wish. if you check the essential prelude links thread at the top of the page there is a link to prelude specs and stats. all your answers are in there. |
Re: Differences between... (shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shakes »</TD></TR><TR><TD CLASS="quote">
dont we wish. if you check the essential prelude links thread at the top of the page there is a link to prelude specs and stats. all your answers are in there.</TD></TR></TABLE> hes the link your talkin about Prelude Specs and Stats https://honda-tech.com/zerothread?id=549372 |
Re: Differences between... (Type_SH)
the auto tranny usually has a 58mm throttle body instead of 60mm. Other than that it should be the same (other than tranny, clutch etc,)
My engine was origianlly auto. It now has a manual from an H23. Bolted right up. No diferences. -- You do need the manuals flywheel. ---
Re: Differences between... (nsxlr8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxlr8 »</TD></TR><TR><TD CLASS="quote">My engine was origianlly auto. It now has a manual from an H23. Bolted right up. No diferences. -- You do need the manuals flywheel. --- </TD></TR></TABLE>
prolly need a manual starter too... |
| All times are GMT -8. The time now is 06:00 AM. |
