Compression test. Good? Bad?
Ok well here are the results
#1 155 #2 185 #3 175 #4 200 This car runs rich and is misfiring, can someone lead me in the direction to resolve this issue? Thanks, Ian Also this car has no CEL showing up, it popped up once and i believe it was the code for misfire cylinder 1 and it was erased and never popped a code since then. |
Re: Compression test. Good? Bad?
those are def not good you should be about 190-220 to be within spec
How many miles are on the engine? |
Bad
what's odd is I *thought* i had a healthy engine but just yesterday I checked mine and they came in at:
150 150 145 150 |
^ Yours is ok, you want all cylinders to be within 10-15% of each other, which yours is. The OP's are not good at all. OP do a leak down test, that will narrow down where your problem is.
all right so is it a ring issue? Or could it be a valve issue? 162-63k miles.
It could be a ring, valve or HG problem. do a leak down test and listen/ watch to see where air is escaping from. If you hear/feel air coming from the TB its the intake valves, if you feel/hear from the exaust its the exhaust valves. If you see air bubbles in the radiator when you take off the cap its most likely the HG. Some air will escape from the Valve cover/ dipstick tube, you just dont want an excessive amount of air coming out of them.
