clutch (release bearing problem)
I recently installed my exedy clutch about 1 month ago and now my release bearing is making some squeaky noise. It seems that my release bearing is loose or something of that nature. If I press my clutch pedaI, the noise would go away. I know I installed it right because the bearing only goes in one way. I even lubricated the bearing before I installed it. Have anybody encounter this problem before when they installed their clutch?
Re: clutch (viperguy)
Did you put a new TOB in when you put in your new clutch? Did you replace just the clutch or did you put in a new pressure plate too?
Is the noise constant unless the clutch is pressed? |
