Can I convert lambo doors to regulars doors?
Looking at buying a 98 SH,only problem is owner has lambo doors on it. Do I just switch the brackets out for regular ones and it will work or is it harder then that?
Re: Can I convert lambo doors to regulars doors?
should be, unless they did a hack job and altered something on the car door frame, etc.
Yes you can you just buy the kit for your prelude. it come with the brackets.
might be easier to just go ahead and convert the rest of the car into a lambo.
Just make sure the hinges are bolted on and not welded on and nothing looks cut up. You should be fine.
Originally Posted by MojicaEric
(Post 47506912)
