ABS Brakes Help!! No brakes & ABS light
Hi all, new here. I read all the searches on master cylinder replacement, and replaced mine myself after the dealer quoted me $600. Nice, huh?
I have a 95 Prelude SE (H23A motor, SI model ABS brakes and suspension). My brake pedal slowly sinks to floor at stoplights. I just (like 10 minutes ago) put in a new master cylinder, bench bled and all. Same problem exists. I start to drive, ABS light clicks and comes on, then pedal sinks slowly to the floor at stops. I have $100 in the new master cylinder already plus 1 hour of my work into it...
Any ideas?
Brad Merrell
The VFR Monkey
http://www.bikepics.com/members/vfrmonkey/99vfr800/
Any ideas?
Brad Merrell
The VFR Monkey
1 Post
Re: ABS Brakes Help!! No brakes & ABS light (vfrmonkey)
If you look behind the radio area, there is a little blue plug. Bend a paperclip and connect both terminals of this plug and turn the ignition to the ON position, but don't start the car. Then look at the ABS light and see if it flashes....if it does, let us know what it flashed (2 long, 1 short, etc...).
/\/\If the ABS system is f'ed up, that will tell you, otherwise I don't know what it would be...
SpeedFreek34
07-22-2007 05:43 PM
fongph
08-23-2006 07:31 AM
