98vtec's h23vtec - 215whp/178tq - 13.43@103
#1251
Re: (BlacktraxGirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlacktraxGirl »</TD></TR><TR><TD CLASS="quote">did you at least get to make another pass???</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">i put the street tires on and made a pass, lol.
pointless, 2.6 60', 10.1 ET LOL.
Blah blah blah both of you need to ship your cars to MD let me take them down the 1320 and take them back after they run what there are supposed to run
#1255
Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">i cant do much if the slicks don't bite. If the clutch could have held it, the car would have jumped off the line.</TD></TR></TABLE>
troof
What are your plans for the clutch then?
troof
#1256
Re: (98vtec)
u should try bleeding the clutch again, maybe you have a leak. and did you adjust the clutch pedal at all??
i used an Action press plate and a stock disc on my H22 for 3 years with 8000 rpm launches on 13x8x25 " slicks with no problems..
try either adjusting the pedal and or rebleeding it before buying another clutch..
where does it engage? low? high?
#1257
moderator emeritus
Re: (h22crxpwr)
it engages where it has been ever since i first installed it. I've always had about an inch of play before the master cylinder engages the slave, likely because i did not bench bleed the master when i first put it in. Never had a problem launching at 8000 with the stock motor and same clutch setup.
It disengages fine and engages where it always has. But when it does engage now, it feels awkward, like its glazed and cant grip the flywheel.
I'll try adjusting the pedal and bleeding again, but i really doubt that is going to solve the problem.
If the clutch/plate is the problem, Billy has a Competition sprung 4 puck on hold for me.
#1259
moderator emeritus
Re: (skunked)
action 2ks
http://www.trackspeedracing.co...K-2KS
yea, i tried a 2nd gear burnout and it wouldnt spin the tires. Also, when i let off the clutch to engage it, the pedal got stuck at the engagement point. I tapped the pedal with my foot and the pedal popped back to its original position. Put it in first and did a burnout.
#1261
moderator emeritus
Re: (skunked)
yea, i referred to it as glazed. But the pedal getting stuck at the engagement point baffled me. I didn't realize it until I realized that the tires were not smoking. I went to push in the clutch and the pedal was not there, lol.
the clutch was installed aug 2006.
#1263
Re: (bonh)
yeah blake when you called and i told you to let the clutch cool down and adjust the pedal...did you try that before putting the street tires on?
sounded like it was glazed and the engagement point was too low.
#1264
Re: (md23vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec »</TD></TR><TR><TD CLASS="quote">
Blah blah blah both of you need to ship your cars to MD let me take them down the 1320 and take them back after they run what there are supposed to run </TD></TR></TABLE>
blah blah blah. its cheaper to fly you out here than to ship our cars to BFE but then why dont you bring YOUR car out here and show us how its done
#1265
Master H Technician
Re: (md23vtec)
Can I get in on this offer?
I know Im in need of a traction bar, a cage, and a diet... Im also as consistent as a <insert something cleverly poor>.
How do we like that thread Hijack Blake?
#1267
Re: (BlacktraxGirl)
blah blah blah. its cheaper to fly you out here than to ship our cars to BFE but then why dont you bring YOUR car out here and show us how its done </TD></TR></TABLE>
Haha I may have to do that <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JTCdudeman »</TD></TR><TR><TD CLASS="quote">
How do we like that thread Hijack Blake? </TD></TR></TABLE>
I wont get started but this is the 2nd thread is seems your trying to discredit my PROVEN car. If you have something to say take it to pm's or make your own thread and call me out.. and/or make your feelings known
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Sorry for the hijack. If you need anything or my slow 2cents I am here for you
#1272
Re: (prelude_93vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_93vtec »</TD></TR><TR><TD CLASS="quote">R.I.P license 1/16/08 - 5/25/08</TD></TR></TABLE>
hahahaha
You made quick work of that, rookie.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">won't be any updates til i have the money to buy the clutch from billy.</TD></TR></TABLE>
Gotta get on the grind son. Hit the streets.
hahahaha
#1273
moderator emeritus
Re: (mgags7)
ok clutch problem is fixed as far as i can tell. It was a few things. The top bolt of the clutch pedal mount had come loose, the rod was loose, the pedal stop had come off and the clutch needed to be rebled. awkward that all that comes loose when i even bled the clutch before i went out and tightened the rod back into place. I put the clutch engagement point right before where the brake pedal sits as per advice via Natalie (thank you) and i also did another trick per advice from roger. I usually put 2 quarts of oil in the transmission through the vss, roger told me to add another half a quarter to the transmission. I am guessing this is to just cover the gears and synchros a bit more, but it definitely feels better.
the next event is at the 1/4 mile on the 28th of this month. I'll likely be attending.
#1274
moderator emeritus
Re: (DrivinVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec »</TD></TR><TR><TD CLASS="quote">I like the paint!! not bad numbers. good job
whats the color called?</TD></TR></TABLE>
all i know is that its MR155.50 (metallic red) and its a 3 stage paint.
