95 vtec h22a running to rich
Old 05-26-2011, 05:01 PM
  #26
circle22's Avatar
Default Re: 95 vtec h22a running to rich
Hey man thank i will go get one tomorrow to test it thank once again
Old 05-26-2011, 06:02 PM
  #27
circle22's Avatar
I will pick one up tomorrow
Old 05-26-2011, 06:36 PM
  #28
Honda owns me
typemismatch's Avatar
Does your check engine light come on when you turn the key to "On"?
This will confirm your check engine light actually works.
Old 05-26-2011, 06:40 PM
  #29
circle22's Avatar
Yes it does but that i find funny that it burnning rich n the light not coming on
Old 05-27-2011, 09:35 AM
  #30
Honda owns me
So your check engine light works, that's good news at least.
These cars are OBD1, up to 96, the check engine light generally means that a sensor has stopped working completely. OBD2 cars have a check engine light that indicates when the engine isn't running right.
Just because the check engine light isn't on, doesn't mean everything is OK.
Old 05-27-2011, 09:40 AM
  #31
Honda owns me
Have you checked that you actually have spark on all four cylinders?
Also, you can do a poor man's engine health/compression check. while the motor is running pull the plug wire off each plug in turn. Does pulling the wire off any cylinder affect the motor less than the others? If you pull a wire and it doesn't affect the way the motor runs, you have a weak or not firing cylinder.
Old 05-27-2011, 10:35 AM
  #32
circle22's Avatar
Hey i did the injectors test no gas came out n yes i did the spark wire test n when i do that to each wire the car want to cut off
Old 05-27-2011, 11:14 AM
  #33
P. Hunter's Avatar
what ecu you running?
Old 05-27-2011, 12:28 PM
  #34
Honda owns me
What modifications do you have done to your car?
Old 05-27-2011, 05:23 PM
  #35
circle22's Avatar
I ont know wat ecu i have when look for the number it dont have any but i was told i can use a p72 ecu is this true?
Old 05-27-2011, 05:38 PM
  #36
Honda owns me
A P72 will run your car, with a tune, you should have a P13.
Old 05-27-2011, 07:05 PM
  #37
circle22's Avatar
Yea cuz ive done every thing u told me check for every thing is ok i also did the fuel it coming back at 40 psi do u think it could be the ecu dat my last thing to check? So u say i need a p13. The reason i ask bout the p72 is cuz boy has a gsr p72 already tuned wit hondata so wat think bout?
Old 05-27-2011, 09:48 PM
  #38
P. Hunter's Avatar
remember that a bad air readings could cause your car to run rich tooo..
Old 05-28-2011, 05:44 AM
  #39
circle22's Avatar
O ok ill look at the air lines also to check them
Old 05-30-2011, 10:15 PM
  #40
circle22's Avatar
Hey guestion? I was driving on the highway n my vtec controler deprogram it self when i tune the car the cor is at -20 the throttle is at 0 and rpm at normal when i came to a stop cor was -7 and the throttle at 100 percent
Old 05-31-2011, 06:24 AM
  #41
P. Hunter's Avatar
you said the car was stock.. what is really done to it?
Old 05-31-2011, 06:33 AM
  #42
Honda owns me
I'm not giving you anymore ideas until you come clean on what is done to your car.
A VTEC controller is a garbage way of tuning your car, not to mention, you could easily have bad settings and bad wiring.
Old 05-31-2011, 03:57 PM
  #43
P. Hunter's Avatar
DOT.
/thread
Old 06-01-2011, 06:36 AM
  #44
circle22's Avatar
Yo im here for help not to play games my motor is stock be side my fuel rail n pressure regulator that all i have n when i got the car it had the vtec controller install already i didnt know how to program it so i took it to get done that all i have so i was trying to get help cuz im running to rich im get poor gas miles i dont know wat els to do
Old 06-01-2011, 08:39 AM
  #45
Honda owns me
*Pulls out jibberish to English dictionary* ... nope, no translation possible ...
Old 06-01-2011, 08:41 AM
  #46
Honda owns me
BTW ... fuel rail? fuel pressure regulator? not modified? bad gas mileage? running too rich??
Hmmmmmmm ... where to start looking ... ??
Old 06-02-2011, 11:35 AM
  #47
circle22's Avatar
lisen bro i dont have any modification on the car .....this is my show car and ive have not been taking the car to car show cuz its getting poor gas mileage..... its running to rich .. wat u want me to lie to u bro sorry bro cant do that if i tell u its stock its stock
Old 06-02-2011, 11:58 AM
  #48
slammedbbs's Avatar
i would look into the fuel pressure regulator for sure and maybe your vtech controller when is vtech set to engage ?
Old 06-02-2011, 02:09 PM
  #49
circle22's Avatar
Question? i got the psi gage for the fuel rail.... Wat should dat be set at?
Old 06-02-2011, 02:16 PM
  #50
Honda owns me
I think it should be around 40 psi.
I just don't understand how you could have problems with running rich and not mention that you have an aftermarket fuel rail, fuel pressure regulator, and VTEC controller ... seriously?
It didn't cross your mind that bumping up your fuel pressure might cause your car to run rich??
What about the VTEC controller? Is it a V-AFC? If so, the "AFC" part of that acronym is "AIR FUEL CONTROLLER", don't you think that's a mod worth mentioning, when you are having AIR FUEL RATIO PROBLEMS?? That is what "RICH" means, TOO MUCH FUEL in your AIR TO FUEL RATIO ...
Seriously man, I'm not really interested in tearing you apart, I'd rather see you get your car fixed and be happy. When you don't mention vital changes to the system you're having problems with, how do you expect people to help you?
Not to mention the ghetto TXT speak doesn't help your case, it makes you seem even more ignorant.
Quick Reply: 95 vtec h22a running to rich
