95 Prelude race only ECU wiring
#26
Re: 95 Prelude race only ECU wiring
You're going to downshift to 1st? That rarely works out well with a manual transmission. At VIR we come out of 45 mph turns in 3rd gear just fine. 1st gear is only going to take you to about 35mph with a 23" tire.
#27
Yes we will get into 1st. With the barber pole race there is a pole in the front and rear streight so each time you come to the pole u turn left and go around it. So when u are existing other cars are entering kinda like figure 8 except slow entersection.LOL
#28
The other race the Enduro the track is shaped like a peanut also a pole in the front and back streight but u go to the inside of the pole. Usually half the race is one direction and the other half is the opposite direction.
#30
The only thing you could do is get adjustable cam gears and do some trial and error testing on a dyno with various settings, but that would break the rules of a stock engine.
#34
Ok I missed the first race on the 7th because of root canal. The 14th will be first race. I am wanting to install new dizzy and would like to make sure timming is set correctly however I do not have the service plug to jump. Can someone tell me which pins on the ecu I need to jump to set timming.
#35
