95 Prelude race only ECU wiring
Old 03-18-2018, 03:07 PM
moto44's Avatar
Default 95 Prelude race only ECU wiring
I have completed the build on my 95 prelude with H22 and 5spd. This is race only enduro/ circle track car. ALL the wires under the dash have been removed and there is no factory insterment cluster. Its starts and runs but will only go to about 6100 rpm. I did have to wire 12 volts to ECU pin A25 to get it started. My question is the other pins that see oil psi, oil level ,coolent temp, speed sensor etc will these need to be grounded at the ecu in order for the VTEC to work. All the guages are mechanical aftermarket. If i do need to ground certain pins which ones?
Old 03-19-2018, 04:54 AM
motoxxxman's Avatar
Default Re: 95 Prelude race only ECU wiring
the ecu doesn't need to see anything from under dash stuff.
Fuel injectors, coil, and any solenoids are all powered by the ignition switch and main relay. If you removed those, you'll need to chase some wiring and connect switches to anything that uses 12v.
all engine sensors and ecu grounds are grounded to the engine itself on the water outlet.
If it has a low rev limit, that means there's a trouble code stored. Check stored codes and diagnose as necessary
Old 03-19-2018, 05:50 AM
moto44's Avatar
There is no original dash or ignition switch wiring it has all been rewired. How would i find a stored?
Old 03-19-2018, 07:40 AM
ross2004's Avatar
You need to wire in a check engine light & toggle switch to flash the codes. Look up an ECU pinout and find the wire for the CEL/MIL and Service Check Signal. The ECU gives ground to the CEL, put 12v+ on the other side of you light. Then, use a toggle switch to switch ground on the service check signal ECU wire. Is your engine harness in tact or has it been done from scratch? If it's from scratch, I'd highly recommend getting an un-cut harness from a junkyard/ebay/etc. There's a few things you can cut out on a race car, but it's all pretty necessary. You really need a Helms manual to look at the wiring diagrams.
Oil psi- only switches a dash light, nothing to ECU so ok there.
Oil level- there isn't one
Coolant temp- very important, goes to ECU
VSS- same
Old 03-19-2018, 07:45 AM
ross2004's Avatar
Race car CEL. Print out a list of the trouble codes, laminate it, and keep it in your trailer/truck.
Old 03-19-2018, 08:27 AM
moto44's Avatar
The under hood harness is all stock and all plugged in. The ecu is a p13
Old 03-20-2018, 03:28 PM
motoxxxman's Avatar
^this^
Old 03-20-2018, 08:14 PM
moto44's Avatar
VSS- same
Coolant sencer is still in place and plugged in but no OEM guage
VSS vehicle speed sencer? Is this the speedo plug?
Old 03-21-2018, 05:05 AM
motoxxxman's Avatar
you don't need the oem gauge. I doesn't communicate with the ecu. The gauge runs off a separate sensor that isn't necessary.
The vss is on the tranny, and runs directly to the ecu. So you don't need any of the oem gauge wiring for that either
Old 03-21-2018, 05:06 AM
ross2004's Avatar
You need the ECU temp sensor, the gauge temp sensor is unnecessary (remove & replace with a real temp gauge/sender). VSS is the speedometer plug (not 100% sure on that, if the gauge gets its signal from this plug as well) on the top of the trans.
Old 03-21-2018, 05:10 AM
ross2004's Avatar
With a P13, the only CEL you should have is for the EGR (assuming you deleted it). It won't cause a problem, but any other codes need to be addressed.
Old 03-21-2018, 06:19 AM
moto44's Avatar
The transmission is out of it rt now do to a 5th and reverse issue but when I removed it the speedo plug was not on. It will be a few days before it is fixed. I' trying to make a practice on the 31 so I what to have it fixed by then.
Old 03-23-2018, 07:35 AM
moto44's Avatar
I don't need the VSS so could I cut the plug and connect the wires. There are three wires so which one would go together
Old 03-23-2018, 11:20 AM
ross2004's Avatar
With a P13, you do need the VSS if you want VTEC to function.
Again, get a Helms.
Old 03-23-2018, 03:26 PM
motoxxxman's Avatar
something tells me this car is going to have nonstop issues...
Old 03-27-2018, 06:47 AM
moto44's Avatar
VSS- same
please elaborate on how to attach a CEL. I' not understanding.
Old 03-27-2018, 07:00 AM
ross2004's Avatar
I can't elaborate too much more than what I did. You take a light that'll work with 12v (I use a Longacre warning light): give it 12v+ from a source of your choosing, and the ground side goes to the CEL/MIL wire from the ECU. Next, you need a toggle switch with ground on the input, output goes to the service check signal wire on the ECU. When this service check signal wire gets grounded by flipping the toggle switch (what you're doing when you jumper the CEL plug normally), your new CEL should start flashing any codes.
Old 03-27-2018, 08:23 AM
moto44's Avatar
ok I'm having my friend who can understand this make me a drawing. When we do get it done will I have to drivethe car to bring up codes? And the car has a master battery switch which is turned off after use. Should I be leaving the battery switch on and only turning off the ignition.
Old 03-27-2018, 08:48 AM
ross2004's Avatar
I'll draw it in a few minutes. I wouldn't leave the kill switch on when it's setting for long periods, you'll just have to accept that the ECU will be reset every time you turn the kill switch off (which isn't a big deal). Leaving it switched on in between heats/races probably won't cause a problem. And yes, some codes will only show up after driving for a while.
Old 03-27-2018, 09:04 AM
moto44's Avatar
That would be very much appreciated if you could make a drawing.
Old 03-27-2018, 09:23 AM
moto44's Avatar
Is this correct
Old 03-27-2018, 10:09 AM
ross2004's Avatar
That's it. Here's the light I use, but use whatever you want: https://www.summitracing.com/parts/lng-41803/overview/
Old 03-27-2018, 08:00 PM
moto44's Avatar
Ok got the CEL wired and come to find out the wiring harness in this car didn't have the pins for vtec. So I installed the proper pins to the ecu.she is running good up to about 7200 were it hits a Rev limiter or it just need a tune up.
Old 03-28-2018, 05:54 AM
ross2004's Avatar
Rev limiter is something like 7600-7700 on a P13- maybe your tach is off?
Old 03-28-2018, 06:23 AM
moto44's Avatar
It' an Autometer tech but I'm fine with the rpm for now. I would like some suggestions about what I Sud do to the ecm to make the engine run a little better at the low end. This is circle track/enduro racing only.don't believe it will ever get out of 2nd gear. At one track I will be shifting from 1st to 2nd two times per lap. That is a Barber pole race. Engine must be all stock
Quick Reply: 95 Prelude race only ECU wiring
