90K mi. check up...
im about to roll over 90K miles and i now this is a big service point what exactly do i need to do? i have recently flushed the tranny, put on new brakes and bled the system. put on new tires, installed new radiator, put on new suspension, and changed the oil. as for everything else i have no idea when it was changed certainly not in the past 10K. What am i gunna need to do to keep her in good condition? thanks!
Re: 90K mi. check up... (LudeTuner)
Timeing Belt
Re: 90K mi. check up... (Cottonwoodz)
water pump
balancer shaft belt JDM blinker fluid |
Re: 90K mi. check up... (GudeH23a)
how much will a new water pump cost? and how hard is it to install?
I believe they are 120ish new from the dealer. They are not hard to install, just take off the old one and install the new one with a new gasket and some honda-bond (i think you use hb on the wp). It is 5 or 6 bolts I believe.
http://www.slhondaparts.com has good prices. |
real dumb but, can anyone tell me where the water pump is? is it above or below the alternator? pics help alot too.
