5th Gen Engine Bay shave
#51
Re: (raylude)
did you find it to be a major pain in the *** to sand and just deal with the area under the shock tower and above the frame rail that's behind that bracket? haha i know that it's a major headache to clean from my experience.
#54
Re: (Mykizism)
Here are some quick update pics.. the motor is ready to go in.. Im waiting for my parts to come back in from Jet-Hot so i can put them on the motor before i drop them into the car. Im waiting for my Turbo/Downpipe/DumpTube/Intake Manifold to come back from jet hot. Im getting them Sterling coated for bling / thermal coating
heres some quick pics bc im tired of seeing all the crappy threads here in the prelude forum..
#56
Re: (Mykizism)
some in the process motor building pics
head was slightly ported intake and polished exhaust side only (i did it), along with supertech valve train.. and a 3-angle valve seat cut by port flow
#61
Re: (madcatz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madcatz »</TD></TR><TR><TD CLASS="quote">unf unf!</TD></TR></TABLE>
what is unf unf?
what is unf unf?
#62
Re: (Mykizism)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism »</TD></TR><TR><TD CLASS="quote">what is unf unf?</TD></TR></TABLE>
lol yea i was wondering the same thing
this makes me wanna pull my engine soon and clean up all my **** too....
#65
Re: (Shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes »</TD></TR><TR><TD CLASS="quote">lookin hot man! keep it up!</TD></TR></TABLE>
from what I see. your autobody skills are greeat.. I've been working in autobody for over 7 years now. Started in highschool and I can say you paint better then some of the painters here at my work. But yet again they have to paint 6-9 cars a day. but still. mad props
btw, how much did you spend for those gravity feed paint guns? I dunno if you know this but some of the holes on the radiator support that you shaved were to clip in the wire that goes to the hood latch but i'm sure a lil doublesided tape will make it work just fine
again nice work
again nice work
#67
Re: (boosted_lude)
Wow. That looks amazing man, love the way the engine looks. What kinda paint did you put on the block/head? I have my engine out right now but i dont have the time to do anything like you have done, but i would like to clean some old stuff. Did you just use high temp black spray paint on the alt/ps and ac mounts?
#68
Re: (tacticalcustoms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacticalcustoms »</TD></TR><TR><TD CLASS="quote">
again nice work </TD></TR></TABLE>
thansks man..
the guns werent too expensive.. a little less than Sata guns.. but not as much as them.. yeah im aware of the holes i shaved on the radiator support.. i didnt like how honda used those clips to hold the hood latch cable and how it was routed.. i rerouted it.. and im using some custom clips to hold it under there
thansks man..
#70
Re: (Revi-Ra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi-Ra »</TD></TR><TR><TD CLASS="quote">Wow. That looks amazing man, love the way the engine looks. What kinda paint did you put on the block/head? I have my engine out right now but i dont have the time to do anything like you have done, but i would like to clean some old stuff. Did you just use high temp black spray paint on the alt/ps and ac mounts?</TD></TR></TABLE>
the black paint im using for the motor mounts, powersteering/ alt / mounts are actually black primer.... i like it how when it dries.. its flat matte black.. so it isnt glossy and shiney in person.. and leaves it with a very subtle look that wont take attention away from the valve cover and turbo..
ive tested this before and the primer leaves a very strong layer of paint, that is resistant to heat, wont fade, and wont stain from dirt and water
engine block and head and tranny is painted with 1200* aluminum paint..
#74
Re: (Mykizism)
The black primer and 1200* paint can be purchased in a spray can? Would a place like home depot or walmart carry em? I wouldnt mind doing this to my mounts since i got em off right now. Also would this 1200 paint work on my header? I got a DC header that is real dirty.
#75
Re: (mgags7)
it actually holds up ok, not as good as i would like it to.. for can paint thats high temp it will do.. its nothing a base coat / clear coat system would be like..
like if oil or water gets on it.. you can spray some orange blast cleaner and it will eat the oil.. but leave the paint alone.. you cant use carb cleaner or any other solvent like that to clean.. it will just melt the paint away.
