Re: 4gen H22 fuel pressure (uncle)
Yeah you probably should because the walbro pumps bump up fuel pressure by like 10psi once installed so its good to have a FPR and gauge to set it right for your application.. https://honda-tech.com/forums/images...es/emsmile.gif
I recommend aeromotive... |
Re: 4gen H22 fuel pressure (Jason kiDD)
thanx for the info. https://honda-tech.com/forums/images/smilies/embeer.gif BTW are there any dealers here on h-t that you know of?
That you will have to search for. But the unit can be bought for about $125 from most places including summit racing, jcwhitney, etc..
Re: 4gen H22 fuel pressure (Que_Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Que_Lude »</TD></TR><TR><TD CLASS="quote">When I put my B&M FPG on my 94, it read 39psi... and that's where it's at now. I just have bolt-ons, so it works fine at oem settings.</TD></TR></TABLE>
That was at idle or WOT? |
Re: 4gen H22 fuel pressure (4bidden)
That is the pressure at Idle...
Wow. That was with stock regulator on a 94 VTEC? Using a B&M gauge I'm guessing?
From my experience, 42-46 psi works well on slightly modded ludes (I/H/E)
Yup, stock FPR on the 94Vtec. I replaced the fuel rail and FPR to AEM and just have it set to 39psi right now.
question.... B&M doesn't list any FPR for the Prelude. Do you guys use the one intended for the Integra GSR or something and it works?
Re: 4gen H22 fuel pressure (cpforyou)
Yes... you basically just cut the top off the stock regulator and bolt the B&M on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden »</TD></TR><TR><TD CLASS="quote">
Are you serious!? I've never seen anyone have their fuel pressure set at 25psi at idle. I do all my adjustments with the vacuum line taken off the manifold and with my finger over it, simulating WOT. I think the WOT pressure I am running is 43ish, with it at about 32-33 idle. </TD></TR></TABLE> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Sport »</TD></TR><TR><TD CLASS="quote">mine's is about 32-33psi at idle and 40-41psi at WOT.</TD></TR></TABLE> Mine is at about the same as these guys. I'm using an electrical fuel pressure gauge and at idle it's just above 30 psi and once I mash on the gas it jumps to around the 40 mark. This is on a 94 h22a1 https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: 4gen H22 fuel pressure (ludelvr)
that is perfect!^^^^^^^^
2.2L Engine (F22A1)
Vacuum Hose Disconnected 36-43 Vacuum Hose Connected 28-35 2.2L Engine (H22A1) Vacuum Hose Disconnected 33-40 Vacuum Hose Connected 25-32 2.3L Engine (H23A1) Vacuum Hose Disconnected 36-43 Vacuum Hose Connected 28-35 |
it think the actual name for it is b&m fuel flo modifier
which isn't the exact same thing as a FPR |
