1999 prelude bucking/bogging under acceleration
I had just replaced my hid’s and wanted to take the car for a drive to see how everything looked and adjust the head lights accordingly, I remember leaving the parking lot and turning left up onto a decent sized hill the car made it up seemingly fine until I got a little of a backfire from the car like a slight sputter almost , so as I came up to the light I shift down to first everything seemed normal , as I took of from the light the car started to sputter a little through the first three gears then about as soon as I hit 4th at about 4K it’s starts bouncing Ana’s jerking really bad , I eventually made it back home with using almost little to no acceleration in fear the car might do it again , anyone have any ideas what’s going on ? |
Re: 1999 prelude bucking/bogging under acceleration
If you were just messing with lights, you probably have a ground issue. The most common ones to cause problems are the ones on the thermostat housing, and the battery to frame and transmission.
Originally Posted by snobordboy
(Post 51882708)
exsisting power and ground , I have CEL for p0131 and p0132 |
codes are for o2 sensor
hows youre basic maintenance?
Originally Posted by TmiK
quick what to do list
usually these things fix bad idle or/and hesitations: - new spark plugs & wires - new distributor cap & rotor - new air/fuel filters - clean injectors/iacv/egr/fitv - bleed the coolant - new pcv - adjust valves and ignition - adjust idle from tb's screw and throttle cable - check does sensors work properly: map, iat and tps (and try calibrating tps) - then check wires, connectors and hoses, check grounds - check ICM and ignition switch (there was 5th gen repair call for this also) check o2 sensors and vacuum/exhaust leaks (check all the seals - IM/header/TB gaskets, injector seals, maybe even buy valve cover gasket set...) check timing. after that: double check timing clogged cat might you give some trouble as well (usually when driving) - check cats condition if none of these seem to work - do compression and leak tests and if you have chipped ecu and youre running it just with basemap, it might not work as well than properly tuned one those are basic maintenance as well. |
Originally Posted by TimiK
(Post 51883051)
hows youre basic maintenance? |
