01 prelude timing belt install
any got a link to how to do a timing belt on a 01 preude h22 i searched forever and couldnt find what i'm looking for please let me know thanks guys
Re: 01 prelude timing belt install
HELMS
^^ If he had a helms he wouldn't be asking here, why are you always asking people to search instead of helping out? Do something productive with your time.
^because there are free helms manuals available on the internet....that he can search for and do it on his own time....not my time.
He's asking for the link, which would have wasted your time just as much is it did writing your reply.
Here it is man, I hope this is what you're looking for: http://www.preludepower.com/forums/s...g+belt+install |
Point being, this is best done with the assistance of the Helm's manual. OP, you can buy it at www.helminc.com, it's the best purchase you can make for your car.
thanks for the link man looks like bitch to do any idea how much the dealer charges lol
Most will be around $800-$1k; about 70% of that is labor. If you don't mind putting the work into it, it's surprisingly not that bad.
Its not that bad bro. The most annoying part will be getting the crank pulley bolt off. Other than that its not that bad (I'm actually doing mine right now). Try to save yourself some money and go for it. Here is another write-up that helps:
http://www.preludepower.com/forums/s...d.php?t=288086 And if you want to do the auto ---> manual tensioner conversion: http://www.collectiveracing.net/crfo...ff073067eee5fe |
ok what if i ruse the auto tensoiner or is this not a good idea?
Originally Posted by blackccoupe
(Post 38971458)
ok what if i reuse the auto tensoiner or is this not a good idea?
(Post 38967442)
At my local Honda dealer they were charging me 325 for timing belt change. This is just for the timing belt. + any other parts that need changing. I was surprised on the quote he gave me, but thats what he gave me.
You should go through the link over and over until it sticks to your head, then go get that parts, that's what I do if I decide to do something on my own, good luck!
Here is the timing belt procedure for the 5th gen
http://i253.photobucket.com/albums/h...ngbelt6-12.jpg http://i253.photobucket.com/albums/h...ngbelt6-13.jpg http://i253.photobucket.com/albums/h...ngbelt6-14.jpg http://i253.photobucket.com/albums/h...ngbelt6-15.jpg http://i253.photobucket.com/albums/h...ngbelt6-16.jpg http://i253.photobucket.com/albums/h...ngbelt6-17.jpg http://i253.photobucket.com/albums/h...ngbelt6-18.jpg http://i253.photobucket.com/albums/h...ngbelt6-19.jpg http://i253.photobucket.com/albums/h...ngbelt6-20.jpg Valve cover install and torque sequence http://i253.photobucket.com/albums/h...valvecover.jpg http://i253.photobucket.com/albums/h...nstall6-45.jpg http://i253.photobucket.com/albums/h...nstall6-46.jpg |
thansk alot guys gonna do it this weekend dont look to bad a lil different from my bseries though lol
k i ordered the parts, except the dam washer that goes behind the bolt that holds both pulleys lol its says the size is 40mm x 1.5mm, but noone has thatsize, anyone know what other size washer will work. honda was out of them go figure please help me out thanks
What was the total price for parts? If you spent more than ~$200, you got raped.
what ? i'm asking what size the washer is lol
What the diagram doesnt say is to put the timing belt on first, align the timing, and then compress the auto tensioner and slide it in. BTW I did this on a sunday and dealer was closed for me to get a compressed holder tool...so I made my own custom one, and it worked perfect.
1 Attachment(s)
I will be attempting my first timing belt change this weekend. Majestic Honda was the cheapest, even with my discount at my local Honda they wanted $650 just for parts. You guys think my parts are over kill lol? Well I have a small oil leak coming from the timing part of my engine, i hear the belt flopping around at times, and its about time my lude gets the tender love and care she deserves!
Let me know if I am forgetting any parts! ------------------------------------------------------------------- Majestic Honda 14520-P13-013 ADJUSTER, AUTOMATIC $72.19 $72.19 91233-PT0-003 OIL SEAL (27X40X8) (NOK) $5.02 $5.02 15114-PT0-003 GASKET B, OIL PUMP (ARAI) $3.30 $3.30 91212-PAA-A01 OIL SEAL (40X52X7) (NOK) $6.03 $6.03 91213-PR3-004 OIL SEAL (29X43X8) (ARAI) $4.98 $4.98 56992-PDE-E01 BELT, POWER STEERING PUMP (MITSUBOSHI) $13.11 $13.11 38920-P0F-J01 BELT, COMPRESSOR (BANDO) $18.95 $18.95 13405-PT0-004 BELT, BALANCER TIMING (UNITTA) $32.11 $32.11 19200-P13-003 WATER PUMP (YAMADA) $63.70 $63.70 19223-P13-300 RUBBER, WATER PUMP SEAL $2.00 $2.00 19222-P13-300 GASKET, WATER PUMP $2.70 $2.70 14400-P13-014 BELT, TIMING (155YU24 A-555) $49.82 $49.82 13407-P13-000 SPRING B, BELT ADJUSTER $2.18 $2.18 13415-P0A-000 BRACKET, BALANCER BELT ADJUSTER $6.06 $6.06 14510-P13-003 ADJUSTER, TIMING BELT $109.48 $109.48 13404-P13-003 ADJUSTER, BALANCER BELT $51.45 $51.45 11811-P13-A00 SEAL, TIMING BELT RUBBER (LOWER) $30.26 $30.26 - Additional Part possible needed (refrence 06111-P5P-020) 14517-P13-003 gasket $1.32 $1.32 - Additional Part 90051-PT0-000 sub belt adjuster bolt $3.56 $3.56 - Additional Part 06111-P5P-020 Gaskets for side engine $34.51 $34.51 - addon (says discontinued, if avialble remove other related gaskets, majestic says its on backorder no arrival date) 15113-P13-003 Oil gasket a $2.72 $2.72 - Additional Part Shipping Information Shipping Method:Fedex Normal Subtotal $515.05 *Sales Tax: $0.00 **Shipping Charge $34.88 Handling Charge $4.95 Total $554.88 |
Originally Posted by dre2day
(Post 44449427)
At this point, I would definitely recommend you to do an H23 manual tensioner conversion and get rid of the Auto Tensioner as it tends to fail over time and cost you around 80-120 depending where you get it from. After the conversion, you will never have to worry about the Auto Tensioner when you replace the t-belt in the future. If you search, there's thread on what you need to complete the conversion and to go about the installation. Good Luck! |
Yea I guess I need to do the conversion. I found the kit for $89, but I am not sure if the belts will still fit or if I have to get h23 belts.
IRP list the parts as all genuine, anyone have experience with their kit? |
