****Prelude Specifications and Stats****
#26
Re: Prelude Stats (kotetu)
http://www.icelord.net/honda/repair/ Mitchell's Honda Prelude IV Repair Manual
#28
Re: Hey I have an Idea. (Bone_Luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bone_Luder »</TD></TR><TR><TD CLASS="quote">just one question what does JDM and USDM stand for? i have an idea but better just make sure</TD></TR></TABLE>
JDM - Japanese Domestic Market
USDM - United States Domestic Market
#29
Re: Hey I have an Idea. (Nick M)
Hey guys what you say we post up what motors that can swap into the different gens and with heavy or little mods?
edit: that is motors what will bolt up to our stock mounts..
#30
Re: Hey I have an Idea. (prelittlelude)
Motors that might be worth knowing for a 4th gen or 5th gen luder
HELP me out boys with more info or corrections...
H series motors:
H22A JDM Red Top motors (satan_srv: Euro-R, Type-S SiR S-Spec, see red top post)
H22A JDM Prelude (DOHC VTEC) 10.6:1 CR
H22A1 USDM Prelude (DOHC VTEC) 93-96 10:1 CR
H22A2 Euro spec (DOHC VTEC)
H22A4 USDM (DOHC VTEC) 97-01
H22A5 97+ 185hp (and 200 in 99> euro/england (DOHC VTEC) 2.2 Vti 4WS + 2.2 Vti-S
H22A6 Prelude SiR export motor (Singapore at least)
H22A7 Accord Type R euro
H23A DOHC VTEC, 1999-2000 JDM 6th gen Accord Wagon SIR
H23A1 USDM Prelude (DOHC NON-VTEC) 92-96 SI/SE
H23A2 Euro Prelude
H23A3 Accord and Rover Euro
F series motors:
F22B1 Accord EXs (SOHC VTEC) 94-97
F23A1 Accord EXs (SOHC VTEC) 98-01
F23A5 USDM SOHC 98+ Accord DX
F22B2 Accord DX/LX 1994-1997
F22a1 Prelude s sohc (non vtec) 92-96, 90-93 accord
F22A4 Accord 1990-1991
F22A6 Accord 1991-1993
F22B JDM Prelude (DOHC NON-VTEC) (H23 with 85mm bore)
F20A4 prelude 97+ 2.0 i
F20A Accord 2.0Si (JDM) 1990-1993, EDM 4th gen Euro '2.0i'
f20B Accord SiR and SiR-T 97-00 (DOHC VTEC)
F23A JDM Accord Wagon SOHC VTEC motor (non-SiR), many JDM 6th gen Accords
Also check out http://www.accordinglydone.com/data.php
Modified by prelittlelude at 11:24 AM 10/12/2003
H series motors:
H23A2 Euro Prelude
F series motors:
#32
Re: Hey I have an Idea. (str8rcn)
This list comes from 2g heaven: http://people.clemson.edu/~summerr/2gsite/
This list contains every Performance part made for the 83-87 Honda Prelude some parts
are listed as Accord because it used the same motor. Most parts have special notes or
part numbers, Please feel free to make any additions and if you need help finding anything
*(SIP)* or Info drop me an email at Rtypeinertia@hotmail.com or on AOL/AIM @
Evocitywerkz. Thank you.
Chris Dodge (JDMET2)
Engines: Paeco (Still In Procuction)
Stage One (146 hp)
Stage SRE (158 hp)
Stage Two (176 hp)
Stage Three (202 hp)
Stage Four (242 hp)
Engine: Paeco Internal (SIP)
Crank
Pistons (custom alum)
Titanium rods
Chrome-moly rods
Main cap girdle
Engine Mount kit: (SIP)
Place Racing (Accord)(B series)
Headers: (Made)
Mugen 4-2-1 W/ Test pipe
Jackson Racing 4-2-1
A/T Engineering 4-2-1
Gude 4-2-1 (Accord)
Rage un-welded4-2-1 (DIY)
Pace 4-2-1
Headers: (SIP)
Paeco 4-1 (Accord 86-89)
D/C Sports 4-2-1 P# (PTHHC5010)
S+S Headers 4-1 P# (5305S)
Pace setter 4-2-1 P# (70-1250)
Exhaust: (Made)
Mugen
Fujitsubo (Japan)
Trust TR (Japan)
Exhaust: (SIP)
Paeco Prima-power (P# HO-16)
Pacesetter P# (88-1417)
Evocity Wërkz Build spec (Email me)
Custom
Cams: (Made)
Jackson Racing
Kent cams (U.K.).
Cams: (SIP)
Paeco P# (HO-6800, HO-7400, HO-7800, HO-8600)
Paeco Valve springs (Dual)
Paeco valve retainers
Crow cams (AUS) P#(ET, BS, ES2/3,BT (131000)(ES1, ET2)(246000)
Web cams P#'s (35-050 Fi .35-040 Carb .35-191 Carb Racing)
Gude P# (HACSO1 Carb)
JG Engine Dynamics P# (6060,7560)
Heads: (Made)
Mugen (Carb only)
Heads: (SIP)
Paeco Prelude (Send core)
Gude (Accord head) P# (HARHO1)
Head gasket: (SIP)
FELPRO
Paeco copper gasket in (.030,.060)
Manifolds: (Made)
A/T Engineering (Canada)
Manifolds: (SIP) (Carb only)
Autoquip (New Zealand)
TWM induction. (Usa)
TWM induction (ES only)
Custom
Carbs: (Made)
Keihin 2bbl & 3bbl
Jackson racing Carb kit (For stock carbs)
Mikuni (Weber copy)
Weber DCOE (40, 45, 50, 55)
Dellorto DHLA (40, 45, 50)
Filters: (SIP & Made)
Forza panel filter (Japan) (B20A5)
K&N P# (33-2521 Fi, E-2925 Carb)
Computer Chip: (SIP)
Jet ECU P# (514+0035)
Pulleys: (SIP)
Paeco ALUM (Crank)
Transmission: (SIP)
Paeco fly wheel ( MK3 5lbs, MK4 8lbs)
Clutchmasters P# (Flywheel: FW-615-AL, Clutch stages 0-5)
Pacesetter Short Shifter Adj. P# (01-0250)
Centerforce P# (DF508340)
ACT P#'s (Carb: HA1-HD00, HA1-HDR4, HA1-HDR6)(Si: HA2-HD00, HA2-HDSS, HA2-HDR4,
HA2-HDR6)
OPM limited slip (Call)
Evocity Wërkz tranny build spec (Auto)
Torque Rod bushings: (SIP)
Evocity Wërkz (Top)
Ignition: (SIP)
MSD Blaster II and III
Crane Cams Ignition system
Any external coil
Wires: (SIP)
Magnecor
Splitfire
NGK (Blue)
Stock
Only use NGK or OEM for best performance
Spark plugs: (SIP)
Splitfire
NGK-R (Best)
NGK
BOSCH Platinum (Do not use the platinum +4 plugs)
Body kits: (Made)
Mugen front bumper
Mugen rear wing
Jackson Racing Interlude kit (FB, SS, RB)
Value Sport lip spoiler (Japan)
Style Auto (Germany)
Stock Si wing
Stock Base/Xx model wing
Body kits: (SIP)
Erebuni #317 (FB, SS, RB)
Evocity Wërkz (FB, RB, LS)
SilverGhost Motorsports (Australia)(FB, SS, RB, HS, WING)( silver_ghost@one.net.au)
Custom
Suspension: (Made)
Jamex -40mm springs
Jackson Racing springs (1.5" drop)
Jackson Racing stabilizer bars
Bilstein BTS-Kit
KYB New-SR (Japan)
Tokico Prodora-G Struts (Japan)
Tokico Illumnia adj. P# (F BU2823, R BU2825)
Monroe Gas struts
DC Sports springs (???)
Koni sway bars (F&R)
Tanabe H200 coil springs (Japan)
RSST H150 Sport springs (Japan)
Heroes Racing spring kit (Japan)
Spats Front strut bar (Japan) (B20A5 only)
Mugen sports damper (Tuned)
Mugen electrically controlled damper (Tunable)
Eibach Pro-kit (1.3”)
Suspension: (SIP)
Paeco bushings
Ground control w/ ERS springs (Natural High Racing) (Tunable)
Tokico premium struts (Blues) P# (Front HB2689, Rear HB2046)
KYB GR-2 struts
Ignalls Camber kit (Front)
Weapon-R coil overs P# (STS11)
Evocity Wërkz rear strut bar
Addco rear sway bar P# (404+609+611+014)
Koni struts (OPM)(Call)
Koni Reds (Classic Garage)(Can be re-valved)
BILSTEIN- made by ennepetal (japan)(wide shaft)
Suspension Techniques (1.0")
Intrax (2.0”)
Brakes: (Made)
Jackson Racing caliper kit 2-Pot
Jackson Racing cross-drilled rotors
Jackson Racing SS brake lines
Brakes: (SIP)
Hi spec 300mm disc 4-pot racing brake conversion (U.K.)
Si calipers 85-87 (Good upgrade for the base model)
Accord calipers LX-i 86-89
AEM/Nissin pads P# (26-051)
Tecna-Fit SS braided brake lines (Natural High Racing)
Axxis metal master pads P#'s ( Si 23-334-01)
Brembo rear rotors P# (083-2147)(You need new bearings)
Ferrodo pads (Base model)
Power slot rotors
EBC Discs and Pads
Wheels: (Made)
Mugen CF-48 (13x5.5, 14x6, 15x6, 37mm offset)
Wheels: (SIP)
Any 4x100 offset 37-45 up to 18x7.0
For a performance application don’t go over a 15-inch wheel
Steering Wheels: (Made)
Mugen SW-36
Mugen SW-36 w/ Cover
Steering Wheels: (SIP)
MOMO hub
Any MOMO or Sparco wheels
Engine Codes
ET-2: 1.8L 12-valve SOHC 2bbl Carb
ES-1/3: 1.8L 16-valve SOHC 3bbl Carb (Asia)
BT-1: 1.8 12-valve SOHC PGM-Fi (UK)
A18A1: 1.8L 12-valve SOHC 1bbl Dwn Dft Carb
A18A2: 1.8L 12-valve SOHC 2bbl Side Dft
A18A3: 1.8L 12-valve SHOC PGM-Fi
A20A1/5: 2.0L 12-valve SOHC PGM-Fi
A20A3: 2.0L 12-valve SOHC PGM-Fi(water-oil cooler)(windage tray)
A20A4: 2.0L 12-valve SOHC PGM-Fi (Canada ’87)
B20A1/5: 2.0L 16-valve DOHC PGM-Fi (Japan-U.K.)
Web sites:
http://www.twminduction.com
http://www.nopi.com
http://www.crower.com
http://www.gude.com
http://www.opmmotorsports.com
http://www.ssheaders.com
http://www.dcsports.com
http://www.pacesetterexhaust.com
http://www.clutchmasters.com
http://www.centerforce.com
http://www.advancedclutch.com
http://www.cranecams.com
http://www.classicgarage.com
Common Problems:
Rear defrost / Hazards switch sticks (replace and superglue the tabs on the side)
Rear view mirror breaks with high heat (email me for fix)
Taillights harness breaks (easy fix) (push silver bulb collar back into plastic)
Idle comes out of adjustment (Adj.)
Emergency brake cable gets stuck (replace)
Automatic transmission breaks with heat (earlier models) (use external tranny cooler)
Modified by racerx at 8:58 PM 8/18/2003
Stage One (146 hp)
Stage SRE (158 hp)
Stage Two (176 hp)
Stage Four (242 hp)
Crank
Titanium rods
Chrome-moly rods
Main cap girdle
Headers: (Made)
Gude 4-2-1 (Accord)
Pace 4-2-1
Headers: (SIP)
Exhaust: (Made)
Mugen
Fujitsubo (Japan)
Trust TR (Japan)
Exhaust: (SIP)
Custom
Cams: (Made)
Jackson Racing
Kent cams (U.K.).
Cams: (SIP)
Heads: (Made)
Mugen (Carb only)
Heads: (SIP)
Head gasket: (SIP)
FELPRO
Manifolds: (Made)
Custom
Carbs: (Made)
Keihin 2bbl & 3bbl
Mikuni (Weber copy)
Pulleys: (SIP)
Paeco ALUM (Crank)
Transmission: (SIP)
HA2-HDR6)
Evocity Wërkz (Top)
Ignition: (SIP)
Any external coil
Wires: (SIP)
Magnecor
Splitfire
NGK (Blue)
Stock
Spark plugs: (SIP)
Splitfire
NGK-R (Best)
NGK
Body kits: (Made)
Mugen front bumper
Mugen rear wing
Stock Si wing
Body kits: (SIP)
Custom
Suspension: (Made)
Jamex -40mm springs
Bilstein BTS-Kit
KYB New-SR (Japan)
Monroe Gas struts
Suspension: (SIP)
Paeco bushings
KYB GR-2 struts
Intrax (2.0”)
Brakes: (Made)
Brakes: (SIP)
Power slot rotors
EBC Discs and Pads
Wheels: (Made)
Wheels: (SIP)
Mugen SW-36
MOMO hub
Engine Codes
Web sites:
http://www.nopi.com
http://www.gude.com
Common Problems:
#34
Re: (bad-monkey)
here's a useful page, though it's mostly in japanese.
http://www.honda.co.jp/auto-li...data/
translate: http://world.altavista.com
#35
Re: (racerx)
4g and 5g Brakes
calipers: Rear calipers are the same on both gens and all models. The 4g S and 4g SI have the same front calipers. The 4g vtec has the same front calipers as the 5g.
brake lines: Different but might work.
perportioning valves: Different, but I need a conformation that the 4g vtecs is different from the SIs. Difference is probably to fix the front/ rear brake bias due to the 5gs bigger calipers and rotors. With a Helms and some rearanging of the brake lines, the valve could be an easy fix for those running Legend calipers on 4g's.
booster: Different mounting for master cylinder but use the same firewall gasket. This is another possible upgrade for 4g's. Need to know brake line pressures and petal ratio to know for sho.
Master cylinder: Different mounting but the same bore. Incidentally, the Legend and NSX's MC bore is also 1".
I also need a conformation from someone. In one of Advanceds brake books, I saw that the '90-'91 Prelude SIs front calipers were the same as the 4g SIs. Can anyone tell me if this is true??? Is this another candidate for Legend calipers?
If anyones got info like this on any system, let see it!
Modified by racerx at 3:19 AM 8/24/2003
#37
Sparkplugs Troubleshooting with Pictures!
Not specifically for Preludes, but this may be very useful to us all
http://sportbikeguy.com/garage/floor/plugread.html
#38
Re: (GODluvsLUDES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GODluvsLUDES »</TD></TR><TR><TD CLASS="quote">BUMP for an outstanding thread that needs to get licked and STICKED!!
One question though:
ECU Types and Numbers
P13 : 93-95 OBD-1 Prelude Vtec
P14 : 93-95 OBD-1 Prelude Si (non Vtec)
P5P : 97-00 OBD-2 Prelude Type-S (JDM ECU)
These are the ECU #'s for our ludes. What about the 1996 Prelude (first year OBD2)? Is it P14 or P5P or something else?</TD></TR></TABLE>
96 is a p13, let me clarify this list,
P13 : 93-95 OBD-1 Prelude VTEC
P13 : 1996 OBD-2 Prelude VTEC
P14 : 93-95 OBD-1 Prelude Si non-VTEC
P14 : 1996 OBD-2 Prelude Si non-VTEC
P5M: 97-01 OBD-2 Prelude Base
P5P: 97-01 OBD-2 Type-SH
P5P : 97-01 OBD-2 Prelude Type-S (JDM)
That's right the P5P type-s ecu is indistinguishable from the USDM type-s by code only.
#39
Re: (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 »</TD></TR><TR><TD CLASS="quote">anybody know the width of the stock si wheels??</TD></TR></TABLE>
Pretty sure all Prelude stock wheels are 6.5" in width.
#40
Re: (satan_srv)
Original thread here https://honda-tech.com/zerothread?id=641555
All the blue and red top engine info you need.
Blue
F20B
Accord/Troneo Sir and Sir-T (CF4) (JDM)
200ps/145tq
notes: (ported head and type-s cams(12.1, 11.2 lift), 2.0L block 11:1cr 85mm pistons
Tranny code T2T4
1-3.285
2-1.956
3-1.344
4-1.034
5-0.870
F-4.266 (yes same ratios as a stock 5th gen)
LSD
H23A VTEC
Accord Sir Wagon (CH9) (JDM)
200ps/163tq
notes: 10.6:1 CR, open deck likely regular JDM H22a head. 95mm stroke
Auto Tranny stock
Red
H22A (Euro-R Spec)
Accord Euro-R (CL1) (JDM)
notes: Type-S head and cams 11:1 CR, single stage manifold,
Tranny T2W4
1-3.285
2-2.090
3-1.481
4-1.071
5-0.812
F-4.266
LSD
H22A7
Accord Type-R (CH1) (Europe)
Notes: Same as Euro-R above, 212hp, dfferent header,
Tranny U2Q7
1-3.285
2-2.090
3-1.481
4-1.071
5-0.870
F-4.266
LSD
Euro-R vs. Type-R powerbands!
H22A (S-spec)
Prelude Type-S and Sir spec-S (BB6)
Notes: Type-S head and cams 11:1 CR, dual stage IM,
1-3.285
2-1.956
3-1.344
4-1.034
5-0.812
F-4.266 (yes same ratios as a stock 5th gen except for 5th)
LSD for SiR spec-s and ATTS for type-s
http://www.honda.co.jp/PRELUDE/2000/
Type-S
Blue
F20B
200ps/145tq
Tranny code T2T4
1-3.285
2-1.956
3-1.344
4-1.034
5-0.870
LSD
H23A VTEC
200ps/163tq
Auto Tranny stock
Red
H22A (Euro-R Spec)
Tranny T2W4
1-3.285
2-2.090
3-1.481
4-1.071
5-0.812
F-4.266
LSD
H22A7
Tranny U2Q7
1-3.285
2-2.090
3-1.481
4-1.071
5-0.870
F-4.266
LSD
H22A (S-spec)
1-3.285
2-1.956
3-1.344
4-1.034
5-0.812
Type-S
#42
Hey do you know the differences between the H23A and H23A1? Cuz I was planning to throw a H23A in my 94 lude. Any feedback is cool.
#46
Re: (jdmh22ek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmh22ek9 »</TD></TR><TR><TD CLASS="quote">is the tranny code the same for the jdm type s and and the sir spec? How can you tell if the tranny has atts or not?</TD></TR></TABLE>
The tranny code for the SIR S-spec is M2B4 (JDM LSD), the Type S tranny code is M2U4(ATTS), same as the USDM type SH. The Type S tranny is the same as The Type SH except for the ATTS which has been modified to accomodate extra features on the Type S that the Type SH does not have. The Type S has variable control ABS, which means when you brake during a corner the ATTS adjusts braking force on all four wheels to prevent a spin out and retain maximum control. The tranny is another indistinguishable item between the Type S and the Type SH.
