Headlight Issue
Old 12-08-2018, 08:27 PM
Default Headlight Issue
Honda Rebel 250, 1994. Does anyone know what might be the problem with my headlight? I was having trouble starting the bike a month ago (Cold start) and the headlight switched off on the second attempt and still will not come back on. The turn signals are working perfectly. I have changed the globe in the headlight and it still does not turn on. Both low beam and high don't do anything. Could this be an earthing issue?
benpt is offline
Old 05-01-2019, 07:44 AM
alaxjordan0's Avatar
Default Re: Headlight Issue
Headlight IssueHonda Rebel 250, 1994. Does anyone know what might be the problem with my headlight? I was having trouble starting the bike a month ago (Cold start) and the headlight switched off on the second attempt and still will not come back on. The turn signals are working perfectly. I have changed the globe in the headlight and it still does not turn on. Both low beam and high don't do anything. Could this be an earthing issue?
Will be so, what you gazed. But I think you need to see it a mechanics.Thanks a lot.
alaxjordan0 is offline
Old 05-10-2019, 06:48 AM
The headlight of a motorcycle is very necessary to a rider. When you are riding your bike at night, low visibility is dangerous for the rider it must happen accident. But it is good news that your backlight works appropriately.
Old 05-15-2019, 12:06 AM
A headlight has increased the glamour of the motorcycle. It is the beauty of a bike. So you must put off this and buy a new one.
Old 05-18-2019, 10:24 AM
In the cold season, the engine of the motorcycle becomes very cold and don't start in the morning. Then need the engine heat. It will be the reason for your headlight turn off.
  • Ask a Question
Question Title:
Description:
