Changing a clutch on GSXR
Re: Changing a clutch on GSXR (ZexyAccord)
Hell ******* no thats not a good deal.
80-100 for the clutch plates...
labor should be an hours worth...two at the max!
I can do it in 45 minutes.
EDIT: SO long as its just the friction plates, steel plates and springs...and not the basket as well...
If your having to get the basket case changed too...then ya i can see it costing that much...however...
Unless your **** is severely fucked...you should only need the new clutchplate kit....which as i said...a Barnett Racing aftermarket clutch plate kti for our bike goes for 145 bucks and thats with springs.
So stock clutch kit is significantly less.
Re: Changing a clutch on GSXR (The Hooligan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Hooligan »</TD></TR><TR><TD CLASS="quote">a good mechanic can do one in 30/45 minutes </TD></TR></TABLE>
Doesnt matter - customer gets charged the book rate no matter how long the job takes... flat rate labor.
Step 1, take off the body panel
Step 2, take off the clutch cover
Step 3, take off the pressure plate cover
Step 4, take out the clutch plates and steel discs and replace with new ones.
Step 5, reverse steps 3-1.
It wouldn't take me more than 30 min.
Re: Changing a clutch on GSXR (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
Doesnt matter - customer gets charged the book rate no matter how long the job takes... flat rate labor.</TD></TR></TABLE>
Wrong.
Crap and **** shops and stealerships go by the book rate no matter what.
Good shops that care about your business do not.
Wrong.
Location: spinning DnB till your head explodes,jersey/philly
1 Post
Re: Changing a clutch on GSXR (4-ageTOg63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-ageTOg63 »</TD></TR><TR><TD CLASS="quote">
Wrong.
Good shops that care about your business do not.</TD></TR></TABLE>
i agree
Wrong.
i agree
Wrong.
Isnt that what I just said?
Wrong.
'good shops' are few and far in between
i work as a automotive tech at a dealership and you get charged like said a flat rate, also you said good shops that care about your business do not??
that must be one whack business, any SMART BUSINESS will charge somehwat close to book rate, if this shop is in your friends back yard i can see them charging only 20min
vtec25
08-04-2006 10:44 PM
