Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Motorcycles (https://honda-tech.com/forums/honda-motorcycles-26/)
-   -   Carburetion problems... or something... (https://honda-tech.com/forums/honda-motorcycles-26/carburetion-problems-something-444117/)
Loco Honkey Mar 15, 2003 07:41 PM
Argh, stupid carbs.
Bike: '92 Yamaha Jog 50cc two stroke scooter.
Carb: Simple slide carb with oil injection.
The bike idles and responds to very small throttle inputs fine. Once I crack the throttle open to take off, it dies like it's lean. It is lean. The problem is, I've checked the tank, fuel lines, filter, pump, vacuum line for the pump, carb, chased float levels around, adjusted the slide needle all over the place, and the goddamn thing still dies when I give it gas. Also, if I manage to get it revved up a few thousand RPM, it dies in about two seconds.
The only things I haven't checked yet are the manifold for any leaks (highly doubtful), and the reeds. But... it doesn't seem like a reed problem! Then again, it's been my experience that if something's up and you've checked all the usual suspects, the reeds are more than likely the culprit. If this is the case, I guess it'd be a good time to upgrade to some Boyensen reeds. ^_^
*mutter* Stupid reed valved two strokes...
rioninja Mar 15, 2003 08:26 PM
Re: Carburetion problems... or something... (Loco Honkey)
Its not a vacuum slide is it?
ie: where the slide isnt directly attached to the throttle cable, and
instead rely on vacuum in the airbox to open the slide.
[Modified by rioninja, 12:26 AM 3/16/2003]
Loco Honkey Mar 15, 2003 08:51 PM
Re: Carburetion problems... or something... (rioninja)
No, it's not a vacuum slide. Cable is attached directly to the slide.
tonydatyga Mar 15, 2003 09:11 PM
You said you played w/ float levels... so the bowls are full and flowing when it runs lean?
Raz1983 Mar 15, 2003 09:12 PM
did you try overhauling your carb?
could be that your MJ is plugged
Loco Honkey Mar 15, 2003 09:16 PM
Re: Carburetion problems... or something... (tonydatyga)
One bowl feeding a monsterous 12mm carb. https://honda-tech.com/forums/images...s/emsmilep.gif And yes, it's flowing.
I've had the carb apart quite a few times tonight playing with crap, recleaning, ect. The thing is spotless.
[Modified by Loco Honkey, 6:17 AM 3/16/2003]
Raz1983 Mar 16, 2003 01:10 AM
then it seems like the reed valve to me
was it running fine before? or did you just get it? you might have a cylinder that is scratched some
Loco Honkey Mar 16, 2003 03:52 PM
Re: Carburetion problems... or something... (Raz1983)
New findings from todays 'tard-a-thon in the hanger...
Nope. Reeds are perfect. I inspected them today. Also, the intake manifold is immaculate- no leaks anywhere.
Well, it has 8900 miles on it, so I speculate it's run fine at one point in the past 11 years. https://honda-tech.com/forums/images...s/emsmilep.gif The guy who gave it to me said he took it apart to clean the carb and never put it back together and it sat for four years. I'm assuming he had the same problems I'm having.
Got it a few weeks ago.
http://thenew.gamesbbs.com/~vassago/.../badpiston.JPG
Surprisingly, the cylinder is perfect. A friend with an Aprilia SR50 gave me his old 50cc piston to use, and it only has 3200 miles on it. I installed that after giving the jug the 'ole ghetto hone. Even if the cylinder was scratched, it wouldn't cause a lean condition at throttle tip in. Interestingly- it only does it under load. I can rev it all night on the stand, but once I'm on it, it bogs. I'm going to try a carb kit and see what happens. I'm at the stage now where I'm going to start throwing parts at it and see what happens.
[Modified by Loco Honkey, 12:52 AM 3/17/2003]
tonydatyga Mar 16, 2003 04:08 PM
parts monkey tech is never a good sign... good luck
Loco Honkey Mar 16, 2003 04:10 PM
Hey, it was free, so even if it costs $500 to get it going, I'm still ahead of the game. The bike is in great condition other than this problem.
Raz1983 Mar 16, 2003 04:21 PM
http://images.honda-tech.com/set1//smile/emsmileo.gif
dont tell me thats the pistons in your bike, cause that is pretty fucked up piston
if the pistons are fucked, it will bog under load (it will run rich though).
the other thing im thinking could be the wheight rollers?
[Modified by Raz1983, 1:22 AM 3/17/2003]
Loco Honkey Mar 16, 2003 04:54 PM
Yeah it is! And it came out of the bike. The one that's in there isn't scored at all.
Piston isn't fucked anymore. The flyweights aren't the problem; the tranny shifts normally. I inspected it last week.
rioninja Mar 17, 2003 12:18 PM
Does the piston you just installed also have a windowed skirt?
If it doesnt, that could be your problem.
Loco Honkey Mar 17, 2003 08:38 PM
It does. It's exactly the same in every dimention.
rioninja Mar 18, 2003 06:28 AM
possible crankcase leak, or basegasket leak.... but it would have to be pretty bad.
