Bare minimum wiring for a CRF motor? - Honda-Tech - Honda Forum Discussion
Old 04-07-2010, 10:41 PM
thumper64's Avatar
Default Bare minimum wiring for a CRF motor?
First, I have to say I hang out over in the 5th generation Civic area, I don't exactly do anything with bikes, so I need a little help.
I'm wanting to build a motorized bike and CRF50 motors look like a good deal.
What's the very bare minimum I need for wiring to make the motor run? I don't care about lights or electric start, it just needs ignition. Would I just need like a CDI box or what?
I want to buy this, if it helps: http://cgi.ebay.com/ebaymotors/88CC-...Q5fAccessories
thumper64 is offline
Old 04-08-2010, 10:42 AM
thumper64's Avatar
Default Re: Bare minimum wiring for a CRF motor?
Bump, someone's gotta know. I found a simple diagram that just included a CDI box, kill and ignition switch. Isn't there usually a battery?
Old 04-08-2010, 08:23 PM
racerxadam's Avatar
I can't answer your question definitively, but there is very little wiring on the 50 and definitely no battery. Check out servicehonda.com and look up oem parts for the CRF50 and look at the wiring harness.
racerxadam is offline
Old 04-09-2010, 12:27 AM
thumper64's Avatar
ok, thanks.
Old 04-16-2010, 08:40 AM
scartail's Avatar
google is your friend. racerxadam is right, that is about as bare as you get.
crf50 wiring diagram.
http://www.50riders.com/photopost/sh...sort=1&cat=all
scartail is offline
Old 06-23-2017, 01:42 AM
I'm trying to just get this 50cc honda cfr running for grandkids....can I use the cheap China wiring and stator kick start? I can get the wiring coil plug stator..says everything needed to start cfr pit bikes...just wanna know if this will work?
Doougiee is offline
Evs-One
Honda Motorcycles
11-04-2017 06:12 AM
nkerr09
Honda Motorcycles
08-03-2017 04:24 PM
mel function
Honda Motorcycles
05-05-2017 04:45 AM
poolpool8
04-01-2017 09:12 PM
Quick Reply: Bare minimum wiring for a CRF motor?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
