2005 CBR600RR Crank No Start/Compression
Old 06-25-2018, 05:31 PM
lude98SH's Avatar
Default 2005 CBR600RR Crank No Start/Compression
I am looking at purchasing an 05 CBR600RR with a crank no start condition. Bike has under 10k and looks to be in decent shape. I was going to check compression prior to buying anything.Generally what numbers should this make compression wise on a stock engine (obviously all readers are different)? I am seeing 178psi in the manual? Also, are there any common issues that would cause this to happen The seller mentioned he thinks its a fueling issue, not sure why he thinks this.
Old 06-25-2018, 05:37 PM
lude98SH's Avatar
Default Re: 2005 CBR600RR Crank No Start/Compression
Owner is saying he believes it is a fuel issue because the pump does not prime key on engine off. I would think relay or fuse before anything else though.....
Old 08-01-2018, 01:08 PM
botboy's Avatar
Shouldn't be hard to verify. Give the airbox a whiff of starting fluid while cranking. If it lights off and then dies as soon as the starting fluid is burned off that would suggest a fuel delivery issue.
cityjack
01-10-2016 07:18 PM
Maldonw
Honda Civic (2001 - 2005)
12-19-2014 03:41 AM
skaternak
40
07-14-2009 06:14 PM
hollowman8904
01-07-2009 08:59 PM
Quick Reply: 2005 CBR600RR Crank No Start/Compression
