Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Service B23
Old 12-09-2016, 08:45 AM
krunchyfrogg's Avatar
Default Service B23
Hello all. I am the proud new owner of a 2006 Honda Ridgeline. It's great.
It has 167,000 miles on it, and the only major repair has been a rebuilt transmission.
I have a little wrench light up when I start the car now, and it says "SERVICE B23 DUE SOON"
I don't own the owners manual and I am not sure what this mean.
Any help is welcome. Thank you.
Old 12-09-2016, 06:17 PM
TyGuy88's Avatar
Default Re: Service B23
B is oil and filter change
2 is air and pollen filter replacement
3 is transmission fluid drain and fill (and transfer case fluid on 4WD equipped vehicles)
Old 12-10-2016, 02:15 AM
Thank you so much.
I've actually just had those things done. How do I reset the warning?
Old 12-10-2016, 03:32 AM
speedlever's Avatar
Hope this helps.
http://www.curryhondaga.com/honda-ma...atlanta-ga.htm
Old 12-10-2016, 03:43 AM
speedlever's Avatar
Any idea why the tranny rebuild was done? I wonder if the tranny fitting to the heat exchanger in the OEM radiator failed allowing coolant to enter the tranny. Google strawberry milkshake of death and you will find a ton of hits on this issue which affects multiple manufacturers and models including Honda/Acura. I have taken the position of replacing the radiator at each TB/WP service as a precaution.
That being said, my 2008 RL tranny was replaced under warranty due to a top gear whine from new. I've had no issues since the replacement and am currently at 102k miles.
exracer65
Honda Civic (2006 - 2015)
10
10-26-2017 09:15 AM
honda_jeff
02-10-2008 06:50 AM
papichullo
11-28-2007 05:20 AM
StinkyTofu
04-29-2002 09:59 PM
Quick Reply: Service B23
